parabolic velocity: simple way to implement this bondary condition?
Old   June 10, 2014, 14:08
Default parabolic velocity: simple way to implement this bondary condition?
Tommy Sp
vitorspadeto is on a distinguished road
hello
I am newbie in openfoam I saw some posts on the subject, at first I was scared. Could someone show me how to implement the parabolic velocity profile to the input of my tube (2D)? What do I do? Thanks for attention and sorry for posting this topic again. If I can implement, I will make a pdf manual for beginners to share here.
Thank you for your attention.
I use OpenFOAM 2.3.0
vitorspadeto is offline   Reply With Quote
Old   June 11, 2014, 04:55
T. Chourushi
Tushar@cfd is on a distinguished road
Using groovyBC you can do that, check out the example on "pulsedPitzDaily".
Refer: http://openfoamwiki.net/index.php/Co...ulsedPitzDaily
Also, you can refer to the chalmer's document. By following the instruction in the document you can use the patch "parabolicVelocity". I don't know much about OF 2.3.0 version, whether this BC is available in the same. If not you can install the BC using the instructions mentioned in the document.
Refer: http://www.tfd.chalmers.se/~hani/kur...yCondition.pdf
Best Luck!
Tushar@cfd is offline   Reply With Quote
How do I prescribe Average Velocity /Total Inlet Flow for a simple channel problem? skuznet OpenFOAM Pre-Processing 4 February 16, 2022 09:44
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 04:58
Condition of Air velocity in Open Channel simulation wes1204 OpenFOAM Running, Solving & CFD 0 May 9, 2014 05:08
implement tangential boundary condition in simple jhuang Main CFD Forum 4 July 10, 2006 04:01
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
