conjugate heat transfer case from two meshes
Old   July 1, 2014, 17:09
Default conjugate heat transfer case from two meshes
Sergey
skuznet is on a distinguished road
Hello!
I've an OpenFOAM mesh for my solid region and a separate mesh for my fluid regions. These meshes were created in NetGen and are in OpenFOAM format, i.e I have a constant/polyMesh
for solid regions and
constant/polyMesh...
for fluid region.
Now I'm trying to combine them into conjugate heat transfer case. I created boundary conditions
0/fluid
0/solid
and copied my meshes into
constant/solid
constant/fluid
and also created
system/solid
system/fluid
Everything looks ok, but when I try to run the case an error occurs:
UCOptSideNetGenCoarser_run$ chtMultiRegionSimpleFoam
|  \\    /   O peration     | Version:  2.2.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.x-37940e0cd1ae
Exec   : chtMultiRegionSimpleFoam
Date   : Jul 01 2014
Time   : 15:02:07
Host   : "ubuntu"
PID    : 5802
Case   : /media/ubuntu/run/UCcases/UCOptSideNetGenCoarser_run
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create fluid mesh for region fluid for time = 0
Create solid mesh for region solid for time = 0
*** Reading fluid mesh thermophysical properties for region fluid
    Adding to thermoFluid
Selecting thermodynamics package
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleEnthalpy;
    Adding to rhoFluid
    Adding to UFluid
    Adding to phiFluid
    Adding to gFluid
    Adding to turbulence
Selecting turbulence model type laminar
    Adding to ghFluid
    Adding to ghfFluid
Selecting radiationModel none
    Adding fvOptions
No finite volume options present
*** Reading solid mesh thermophysical properties for region solid
    Adding to thermos
    type            heSolidThermo;
    transport       constIso;
    thermo          hConst;
    equationOfState rhoConst;
    specie          specie;
    Adding to radiations
Selecting radiationModel opaqueSolid
Selecting absorptionEmissionModel constantAbsorptionEmission
Selecting scatterModel none
    Adding fvOptions
Time = 1
Solving for fluid region fluid
#0  Foam::error::printStack(Foam::Ostream&) in "/home/sergkuznet/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/home/sergkuznet/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  void Foam::fvc::surfaceIntegrate<Foam::Vector<double> >(Foam::Field<Foam::Vector<double> >&, Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/sergkuznet/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#4  Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<Foam::Vector<double> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/sergkuznet/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#5   at gaussDivSchemes.C:0
#6  Foam::fv::gaussDivScheme<Foam::Tensor<double> >::fvcDiv(Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/home/sergkuznet/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#7  Foam::tmp<Foam::GeometricField<Foam::innerProduct<Foam::Vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<Foam::Tensor<double> >(Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/home/sergkuznet/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libcompressibleTurbulenceModel.so"
#8  Foam::compressible::laminar::divDevRhoReff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const in "/home/sergkuznet/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libcompressibleTurbulenceModel.so"
 in "/home/sergkuznet/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/bin/chtMultiRegionSimpleFoam"
#10  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11
Floating point exception (core dumped)
I have now idea what does it mean. Can anyone help me to resolve this problem?
Here is the case: (15 Mb):
HTML Code:
https://dl.dropboxusercontent.com/u/32508045/UCOptSideNetGenCoarser_run.tar.gz
http://dl.dropboxusercontent.com/u/3...ser_run.tar.gz
Thank you!
skuznet is offline   Reply With Quote
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 05:07
Suggestions for a multi region conjugate heat transfer problem maddalena OpenFOAM 14 September 4, 2013 18:03
Conjugate heat transfer ali_1364reza FLUENT 1 May 31, 2012 09:38
Conjugate heat transfer in reacting flow ali_1364reza OpenFOAM 1 May 30, 2012 14:15
Conjugate heat transfer ali_1364reza CFX 3 May 30, 2012 07:42
