chtMultiRegionSimpleFoam constAnIso --> Anialpha
Old   July 21, 2014, 05:19
Default chtMultiRegionSimpleFoam constAnIso --> Anialpha
Christopher2 is on a distinguished road
Hi guys,
I am using the chtMultiRegionSimpleFoam solver of OpenFOAM 2.3. In my case I have two solids (black and red) and one fluid (blue). The black solid part has anisotropic material properties for kappa.
At first the case was running and I got none-real results. Then I fixed the following BUG (commit: 512931dba2200781f726c9cd7c68f4458fcf31fe).
Now I have some problems with this case. I get an error and a "request for volSymmTensorField Anialpha from objectRegistry", if I change "kappa solidThermo" to "kappa directionalSolidThermo".
1.) How have I to treat the interface between solid-solid and solid-fluid?
2.) What is Anialpha?
3.) Does Anialpha replace kappa?
Till now I am using the following conditions for the interfaces:
solid-solid
type compressible::turbulentTemperatureCoupledBaffleMix ed;
Tnbr T;
kappa solidThermo; (--> kappa directionalSolidThermo)
kappaName kappa;
value uniform 300;
solid-fluid
Tnbr T;
kappa fluidThermo;
kappaName kappa;
value uniform 300;
Did someone run a similar case before and can help me?
Christopher2 is offline   Reply With Quote
STL -> GMSH -> OpenFOAM eric.m.tridas OpenFOAM 7 September 7, 2011 12:06
1.7.x -> buoyantPimpleFoam -> hRhoThermo -> incompressible and icoPoly3ThermoPhysics? will.logie OpenFOAM Programming & Development 1 February 16, 2011 20:52
1.7.x -> buoyantPimpleFoam -> hRhoThermo -> incompressible and icoPoly3ThermoPhysics? will.logie OpenFOAM 0 December 16, 2010 07:08
CAD -> gMsh -> enGrid -> OpenFOAM Problem AlGates OpenFOAM 7 August 6, 2010 12:46
Cyclic Boundaries -> Match Option -> Arbitrary Derek Siemens 1 August 4, 2004 22:06
