how to apply turbulence model to a rhocentralfoam case ? |
October 27, 2014, 19:33 |
Rep Power: 12 |
Hello to all OpenFOAM users here. I have only recently tried to use OpenFOAM for recreating simulations which I previously done with CFX.
The case is quite simple - diamond airfoil in supersonic flow. I used the wedge tutorial from OpenFOAM for template. Nevertheless, I was unable to find a rhocentralfoam example with RAS model (I found all of them were using laminar model). This is why I have several things to ask :
Thanks for everyone's support here. |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 15:13 |
Implement an les turbulence model | pante | OpenFOAM Programming & Development | 19 | December 5, 2014 16:16 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
k-e turbulence model for 3D case | Serge A.S. | Main CFD Forum | 7 | September 10, 2007 11:50 |
