dynamicMesh settings for contraction of a channel or cylinder
Old   September 17, 2014, 08:32
Default dynamicMesh settings for contraction of a channel or cylinder
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
I am trying to move surfaces of a mesh with success but i have a problem at the moment:
  • Want to move a cylinder surface into its centre line is not successful at them moment... as far as I understand there is no correct BC for this problem?
  • In my simple case (see attached pictures) I am moving surfaces (left, right) of a channel into its centre line. That is working (pic2) and the results are as assumed.
  • Doing the same thing now with two more surfaces (left, right, front and back) then I have the problem, that I got crazy deformation at the corners (see pic3). This is also assumed and I know why that happen. Still I dont know how to solve it.
  • I tryed splitting the mesh in more faces that I can make other settings in the motion file but its not working.
  • Does anybody know how to deal with that?
  • At least I want to know if its possible to deform the surface with an profile (like parabolic etc.)?
Thanks in advance,
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
[ICEM] Block meshing strategy for a radiused cylinder Polarbear ANSYS Meshing & Geometry 2 June 18, 2014 14:24
flow around a cylinder pXYZ Main CFD Forum 14 July 25, 2011 10:05
Open Channel Boundary Conditions via journal Matteo FLUENT 0 January 21, 2008 11:05
Simulating square cylinder using cartesian grid? zonexo Main CFD Forum 5 October 10, 2005 08:12
