pressureGradient dictionary
Like Tree1Likes
  • 1 Post By Mojtaba.a
Old   March 8, 2013, 11:11
Default pressureGradient dictionary
Davide D.
dav.dap83 is on a distinguished road
I need to implement a pressureGradient force for spray parcels. I want to simulate gas parcels into a liquid using sprayFoam.
However, pressureGradient force needs a dictionary, and I have not been able to find an example of such a dictionary.
Can anyone provide an example, please?
Thanks
dav.dap83 is offline   Reply With Quote
Old   March 13, 2013, 22:53
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Voila!
    particleForces
		gravity;
		pressureGradient
			U	U;
Note: This works for 2.1.x
chegdan is offline   Reply With Quote
Old   October 4, 2014, 23:41
maysmech's Avatar
maysmech is on a distinguished road
Originally Posted by chegdan View Post
Voila!
    particleForces
        gravity;
        pressureGradient
            U    U;
It doesn't work with DPMFoam in 2.3.0
maysmech is offline   Reply With Quote
Old   October 5, 2014, 06:21
Davide D.
Originally Posted by maysmech View Post
In DPMFoam the velocity field of the fluid phase is named with Uc rather than U. So you just need to write:
    particleForces
        gravity;
        pressureGradient
            U    Uc;
Old   October 5, 2014, 20:13
maysmech's Avatar
    particleForces
        gravity;
        pressureGradient
            U    Uc;
Thanks, But it leads to this error:
--> FOAM FATAL ERROR:
    request for volVectorField Uc from objectRegistry region0 failed
    available objects of type volVectorField are
1(U.air)
    From function objectRegistry::lookupObject<Type>(const word&) const
    in file /home/aut/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 198.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const at ??:?
#3  Foam::PressureGradientForce<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > >::cacheFields(bool) at ??:?
 at ??:?
 at ??:?
 at ??:?
 at ??:?
 at ??:?
#9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
 at ??:?
Aborted (core dumped)
DPMFoam uses U.air for velocity so using U.air instead of Uc leads to:
--> FOAM FATAL IO ERROR:
keyword DUcDt is undefined in dictionary "/home/user/OpenFOAM/aut-2.3.0/run/tutorials/lagrangian/DPMFoam/testSaffman/constant/kinematicCloudProperties.solution.interpolationSchemes"
file: /home/user/OpenFOAM/aut-2.3.0/run/tutorials/lagrangian/DPMFoam/testSaffman/constant/kinematicCloudProperties.solution.interpolationSchemes from line 27 to line 29.
    From function dictionary::lookupEntry(const word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 437.
FOAM exiting
Old   January 11, 2015, 17:48
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
1(U.air)
FOAM aborting
 at ??:?
 at ??:?
 at ??:?
 at ??:?
 at ??:?
 at ??:?
FOAM exiting
Try
        rho.air             cell;
        U.air               cellPoint;
        mu.air              cell;
        DUcDt            cellPoint;
kk2017 likes this.
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
writing subDict in a dictionary ubaid OpenFOAM Programming & Development 3 October 25, 2014 17:17
New Boundary Condition: Reading Dictionary Problem Koga OpenFOAM Programming & Development 0 November 26, 2012 05:01
Reading from User Defined Dictionary File brosemu OpenFOAM Running, Solving & CFD 2 March 30, 2009 15:25
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
FoamX error aachenBomb case Ervin Adorean (Adorean) OpenFOAM Pre-Processing 13 March 7, 2005 03:50
