cHT: Maximum number of iterations exceeded From function thermo... |
January 19, 2015, 09:10 |
Eugen
Rep Power: 11 |
for understanding i made a steady state conjugated heat transfer case with a solid cube that has a bore. There is a fluid moving through the bore and one side of the cube is being fixed at 500K. Other sides are adiabatic. At this stage i didn't want to simulate the heat transfer at interfaces. I just wanted to create a case that can be solved. But i get an error message: Code:
Time = 0.1 Solving for fluid region Fluid DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.0174955, No Iterations 6 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0322661, No Iterations 5 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.00218862, No Iterations 6 DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.0112376, No Iterations 2 [0] [0] [0] --> FOAM FATAL ERROR: [0] Maximum number of iterations exceeded [0] [0] From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const [0] in file /home/opencfd/OpenFOAM/OpenFOAM-2.3.0/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76. i attached the case except my mesh because its too big to attach. |
January 19, 2015, 09:51 |
anonymous
Rep Power: 12 |
Remove de maxIter command for all the variables in the fvSolution.
You should increases de nonOrthonogalCorrectors also. And maybe you should improve your mesh it doesn´t seem very good, although I'n not used to work with chtFoam and maybe the solid mesh requirement is quite low |
January 19, 2015, 09:59 |
Eugen
Rep Power: 11 |
Thank you for your reply.
I set the maxIter because I tried a fix that helped in another thread. Now removed it from both regions and i set nNonOrthogonalCorrectors to 20 but the result is the same unforunately. I will change my mesh and try again. |
January 20, 2015, 03:36 |
Eugen
Rep Power: 11 |
Maybe printStack can be of more help?
[0] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [0] #1 Foam::error::abort() at ??:? [0] #2 Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy>::T(double, double, double, double (Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy>::*)(double, double) const, double (Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy>::*)(double, double) const, double (Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy>::*)(double) const) const at ??:? [0] #3 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:? [0] #4 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() at ??:? [0] #5 [0] at ??:? [0] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [0] #7 |
January 22, 2015, 06:27 |
Derek Mitchell
Rep Power: 13 |
did you do anything to allow for the non-conformal mesh at region boundaries? or is the mesh conformal?
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET |
September 1, 2016, 09:57 |
larmes
Rep Power: 9 |
did you solve this problem?
Maximum number of iterations exceeded Thermo | CoolKau | OpenFOAM Running, Solving & CFD | 2 | October 9, 2014 05:30 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 05:55 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
