timeVaryingMappedFixedValue not Updated with refineMesh (v2006) |
May 10, 2021, 09:32 |
Rep Power: 12 |
Foamers,
My case is a large mesh (~450e6) which causes blockMesh to fail (bad number). I got around that problem by starting with a coarse mesh and using refineMesh -parallel after decomposePar. I'm using timeVaryingMappedFixedValue at the inlet and when I got to run pisoFoam I get an error like this: Code:
[3357]--> FOAM FATAL IO ERROR: [3357] size 501 is not equal to the given value of 2004 [3357] [3357] ... /processor3357/0/U.boundaryField.inlet at line 58 to 60. [3357] From Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = Foam::Vector<double>; Foam::label = int] [3357] in file [3202] I've tried several combinations like: Code:
decomposePar refineMesh decomposePar -fields Code:
decomposePar refineMesh decomposePar -copyZero Code:
decomposePar -noZero refineMesh decomposePar -copyZero Code:
decomposePar refineMesh reconstructPar |
decomposepar, mappedfixedvalue, refinemesh, timevarying |
OpenFOAMŪ v2006: New and updated solvers and physics | OPFO | OpenFOAM Programming & Development | 0 | August 28, 2020 06:57 |
[OpenFOAM.com] complile v2006 with runTimePostProcessing functionality | snak | OpenFOAM Installation | 2 | August 1, 2020 08:08 |
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing | Regis_ | OpenFOAM Meshing & Mesh Conversion | 2 | June 4, 2015 13:44 |
[mesh manipulation] checkMesh Erros after refineMesh | mgdenno | OpenFOAM Meshing & Mesh Conversion | 10 | October 14, 2014 05:16 |
[mesh manipulation] Cannot get refineMesh to run in parallel | smschnob | OpenFOAM Meshing & Mesh Conversion | 2 | June 3, 2014 11:20 |
