Segmentation error
Old   May 7, 2015, 11:23
Default Segmentation error
Everton Santos
dumas is on a distinguished road
Hello foamers,
I have a big problem, I'm doing a solver to simulate the mass transfer which I called wA along the solver with a heat transfer and turbulent flow.
Compile the solver, but is apparently correct when I simulate my case got this error.
My OpenFOAM is version 2.3.
wAFoam solver and wA the case study, the mesh is ready to be simulated there is no need to use blockMesh command.
I thank you for the help and sorry for my bad English.
Create time
Create mesh for time = 0
Reading transportProperties
Reading field wA
Dterm p
Dterm [0 2 -1 0 0 0 0] 1e-05
Reading field p
Reading field T
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
sigmaEps 1.3;
No finite volume options present
PIMPLE: Operating solver in PISO mode
Starting time loop
Courant Number mean: 4.15 max: 5.00000000000001
deltaT = 0.1
Time = 0.1
waEqn...begin
DILUPBiCG: Solving for wA, Initial residual = 1, Final residual = 5.82676605286423e-06, No Iterations 1
Calculating kc and Sh
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigSegv::sigHandler(int) at ??:?
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
#4 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
Segmentation error
dumas is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
