[swak4Foam] implicit Source
Old   May 22, 2015, 07:52
Default implicit Source
hxaxtma is on a distinguished road
I want to simulate an Vortex induced over a cellSet in my domain. Therefore, I added the momentoumSource() compatibility to my solver and recompiled it. So far so good.
Question is about my SourceDict itself, I want to access the created faceZone and add there some velocity distribution over the cells.
This is my Dictionary so far:
vortexSource
    type vectorSwakImplicitSource;
    active true;
    timeStart 0;
    duration 5;
    selectionMode faceZone;
    cellZone    vortexZone;
    variables (
        "xMin=min(pos().x);"
        "xMax=max(pos().x);"
        "yMin=min(pos().y);"
        "yMax=max(pos().y);"
        "zMin=min(pos().z);"
        "zMax=max(pos().z);"
        "alpha=1;"
        "r=mag(pow(xMax/2,2)+pow(yMax/2,2));"
        "vx=-0.5*alpha*r;"
        "vy=alpha*r;"
        "vz=1;"
        dimensions [0 1 -2 0 0 0 0];
        expression  "vector(vx,vy,vz)";
The code runs but no Source is induced over the cellSet, it only gives the regular flow results of the internal Field calculated by the solver.
Where is my problem?
Thanks in advance
hxaxtma is offline   Reply With Quote
Old   May 22, 2015, 15:29
no one has an idea what is wrong?
Old   May 25, 2015, 17:23
Assistant Moderator
Bernhard Gschaider
Which version of swak, which version of OF? Anyway: in my dev-version Examples/BasicSourceSubclasses/pitzDailyWithImplicitSource/constant/sourcesProperties looks like this
plug
    active true;
    timeStart 0;
    duration 1e7;
    selectionMode all;
    vectorSwakImplicitSourceCoeffs {
        switchExplicitImplicit true;
        variables (
            "xMin=0.05;"
            "xMax=0.075;"
            "resist=1e3;"
        expressions {
            U "(pos().x<xMax && xMin<pos().x ? -resist : 0)";
        dimensions [0 0 -1 0 0 0 0];
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
[swak4Foam] difficulties installing swak4foam newbie29 OpenFOAM Community Contributions 120 October 21, 2022 04:01
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 17:25
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
