Inlet velocity as parabolic function
Like Tree1Likes
  • 1 Post By @cfd
Old   July 20, 2017, 05:58
Default Inlet velocity as parabolic function
@cfd
@cfd is on a distinguished road
hi guys. i am new foamer. i am really struggling to specify the inlet velocity as a parabolic function depending from space (so not from time!). Say for parabolic function as
v = -1.3 + 2.3x^2
I have tried two approaches that are explained in https://openfoam.org/release/2-1-0/b...me-dependent/:
First Approach:
i have computed v by matlab and created a two column data.csv file with in the 0th column have steps and in the 1st column having the value of v. After that i have done the following in 0/U in openfoam to read the csv file:
boundaryField
    inlet
        type            uniformFixedValue;
        uniformValue    csvFile;
        uniformValueCoeffs
                refColumns              0;
                componentColumns        (1);
                separator               ",";
                fileName                "data.csv";
After running the icoFoam, i get the following error:
Create time
Create mesh for time = 0
PISO: Operating solver in PISO mode
Reading transportProperties
Reading field p
Reading field U
--> FOAM FATAL IO ERROR:
keyword nHeaderLine is undefined in dictionary "/home/laptop/OpenFOAM/of-dev/run/assignmentFlow/0/U.boundaryField.inlet.uniformValueCoeffs"
file: /home/laptop/OpenFOAM/of-dev/run/assignmentFlow/0/U.boundaryField.inlet.uniformValueCoeffs from line 29 to line 32.
From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const in file db/dictionary/dictionary.C at line 566.
Second Approach:
boundaryField
    inlet
            uniformValue    polynomial ((-1.3 0.0) (2.3 2.0));
After running icoFoam, the following error is produced:
Create time
Reading field p
Reading field U
Expected a '(' while reading VectorSpace<Form, Cmpt, Ncmpts>, found on line 26 the doubleScalar 0.1
file: /home/laptop/OpenFOAM/op-dev/run/assignmentFlow/0/U.boundaryField.inlet.uniformValue at line 26.
    From function Foam::Istream& Foam::Istream::readBegin(const char*)
    in file db/IOstreams/IOstreams/Istream.C at line 92.
FOAM exiting
can someone please help to debug these error?
is there any other way to insert inlet velocity as function of x in OpenFoam?
@cfd is offline   Reply With Quote
Old   July 20, 2017, 06:09
Brian Willis
Dipsomaniac is on a distinguished road
Have a look at using groovyBC.
Last edited by Dipsomaniac; July 20, 2017 at 06:12. Reason: I actually don't think codedFixedValue was a good suggestion.
Dipsomaniac is offline   Reply With Quote
Old   July 29, 2017, 15:43
@cfd
bit of a late reaction but groovyBC works fine! Thanx a lot!
Dipsomaniac likes this.
codeDict Error Parabolic Power Law Inlet Velocity Profile Sindibad OpenFOAM Running, Solving & CFD 0 January 1, 2017 19:53
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 10:20
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
