August 2, 2015, 00:09 |
Apply heat flux boundary condition
nasir musa yakubu
Rep Power: 12 |
I am completely new to OpenFOAM and would really appreciate any input or guidance you can provide on how to set up a case for the problem-discussed bellow. I have conducted an optical ray tracing analysis on software called tonatiuh and did the post processing on Mathematica. The result of this procedure is a flux distribution profile at the aperture of a solar receiver. The 3D flux distribution profile can be exported in STL and VTK file formats, which are both OpenFOAM compatible i assume. Also, the flux profile can also be exported in a table format (100 x 100). Meaning The 3D flux profile has energy density (W/m2) on the Z-axis, and the X, and Y-axis represent the cross section of the aperture (spot focus radius, r=3.0 cm). The fundamental issue is coupling the exported 3D flux profile from Mathematica (in .STL or .VTK formats) with OpenFOAM software and using the flux profile as a radiation (heat source) boundary condition. Also, I am using a Macpro with 64gb RAM and 12 cores. However 3d meshing using netgen on salome seems to take a very long time and always fails due to “ overlapping boundary”. So now am planning on using SnappyHexMesh, as it seems like the best method to apply. kind regards |
Problem with Turbulent Heat Flux Temperature boundary condition | Manuel CFD | OpenFOAM Running, Solving & CFD | 11 | March 17, 2016 15:12 |
Temperature and heat flux wall boundary condition | L. Hamid | Main CFD Forum | 3 | February 22, 2014 21:10 |
How to set the Heat Flux boundary condition at Outlet | creddy_trddc | CFX | 3 | September 21, 2011 07:44 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
