November 6, 2014, 11:03 |
Map patches
Rep Power: 13 |
is there a possibility to map exclusively the patch surfaceFields from one mesh to another? I could use mapFields an then overwrite the volumeField values. But the interpolation of the volumeField takes too much time. Thanks |
September 21, 2015, 21:45 |
Rep Power: 13 |
Did you get your answer? I am having the same problem
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
[Commercial meshers] fluentMeshToFoam: "fluent patch type shadow not recognised" | preibie | OpenFOAM Meshing & Mesh Conversion | 28 | March 29, 2017 04:56 |
Case running in serial, but Parallel run gives error | atmcfd | OpenFOAM Running, Solving & CFD | 18 | March 26, 2016 12:40 |
[blockMesh] Merging edge patches | Yosmcer | OpenFOAM Meshing & Mesh Conversion | 11 | November 16, 2014 14:51 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
