Preprocessing for complex conjugate heat transfer (CHT) |
November 12, 2015, 03:35 |
Anton Kidess
Rep Power: 29 |
I have a complex gemoetry with five regions with heat transfer over multiple surface contacts. It is quite tedious to manually separate the contact surfaces into patches and apply thermal baffles there. CFX for instance is able to recognize overlapping surface areas and allows me to specify separate boundary conditions there. I'm wondering if OpenFoam can also do something like that with some preprocessing tool. I would supply multiple STLs for the separate regions, and would like OpenFoam to make the boundaries accordingly. An additional difficulty would be that the mesh would not necessarily be conformal with such an approach. Has anyone tackled a similar problem?
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
Conjugate Heat Transfer: Wall Heat Flux at Coupled Walls? | MaxHeat | FLUENT | 4 | September 14, 2017 10:44 |
Easiest way of Generation of Conjugate Meshes for CHT Conjugate Heat Transfer | mitra22 | ANSYS Meshing & Geometry | 0 | April 25, 2014 10:52 |
Conjugate heat transfer in a counter flow heat exchanger | abhijithmohan | FLUENT | 2 | March 23, 2014 08:10 |
Conjugate Heat transfer in CFX | ksp1717 | CFX | 11 | December 10, 2010 22:07 |
Conjugate heat transfer with periodic boundaries | Suresh | FLUENT | 0 | February 23, 2009 09:51 |
