Initializing cylinder/sphere phase in 5° wedge |
February 16, 2016, 10:46 |
Manuel do Nascimento
Rep Power: 14 |
I am trying to work with a wedge geometry with a solver based on interFoam. One phase has the shape of a sphere in the beginning. So my geometry is very similar to this one: https://openfoamwiki.net/index.php/M...C4.2C5.2C2_.3F When I was working with two- and three-dimensional meshes I used to initialize my alpha1 phase with the cylinderToCell resp. sphereToCell functions in the setFields file. So, now that I have changed to the wedge shape, those functions don't seem to result in a reasonable cylindric or spherical shape. My mesh: convertToMeters 1.0e-2; vertices ( (0 -0.5 0) // V00 (0.49952 -0.5 0.02181) // V01 (0.49952 0.5 0.02181) // V02 (0 0.5 0) // V03 (0.49952 -0.5 -0.02181) // (0.49952 0.5 -0.02181) // ); blocks ( hex (0 4 1 0 3 5 2 3) (350 700 1) simpleGrading (1 1 1) ); patch top ( (3 5 2 3) ) patch bottom ( (0 4 1 0) ) patch walls ( (1 4 5 2) ) empty achse ( (0 3 3 0) ) wedge wedge1 ( (0 1 2 3) ) wedge wedge2 ( (0 3 5 4) My setFields cylinderToCell { p1 (0 0 -0.001); p2 (0 0 0.001); radius 0.001; fieldValues ( volScalarFieldValue alpha1 1 |
Rep Power: 14 |
The result:
It looks like the cylinder was rotated 90°, but I am sure it is not. The cylinder's axys should point in z-direction. |
February 16, 2016, 12:04 |
Rep Power: 14 |
I installed swak4foam to ues funkySetFields:
funkySetFields -field alpha1 -expression 0 -time 0 -keepPatches -condition "pow(pos().x,2) + pow(pos().y,2) < pow(0.001,2)" SAME result ... any ideas? |
[Other] Wedge patch '*' is not planar | LilumDaru | OpenFOAM Meshing & Mesh Conversion | 6 | January 12, 2021 05:55 |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
[swak4Foam] mass conservation of solid phase violated when using groovyBC with twoPhaseEulerFoam | xpqiu | OpenFOAM Community Contributions | 8 | June 17, 2015 02:08 |
iteration questions in discrete phase | iknowjesus | FLUENT | 4 | March 13, 2015 06:07 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
