How and where to Define a CellZone Properties?
Old   March 24, 2016, 13:39
Default How and where to Define a CellZone Properties?
SCHOLZC is on a distinguished road
Hey CFD community!
I am working on an injector case where I want my impinging elements to ignite at their impingement point. I have defined a box region at this point, and want to set it to a high temperature for ignition. How and where do I go about defining this region's temperature?
SCHOLZC is offline   Reply With Quote
Old   March 24, 2016, 14:04
Vinícius da Costa Ávila
avila.vc is on a distinguished road
Hi.
Take a look at src/fvOptions/constraints/derived/fixedTemperatureConstraint (of30x)
I have never used this option, but if I understood correctly, that's the fvOptions settings you should apply. Take a look at the header file and the code. You may also look if there is a tutorial that uses it by typing grep -r "fixedTemperature..." .../(specify tutorials folder) on the terminal window.
Best luck
Vinícius dC.A.
avila.vc is offline   Reply With Quote
cellzone, combustion, ignition
