June 21, 2016, 16:53 |
Multiregion solid-solid coupling bc
James Feng
Rep Power: 12 |
I'm trying to set up a chtMultiRegionFoam case where there are solid-solid interfaces. The tutorial cases (such as the snappy) all interfaces use "type compressible::turbulentTemperatureCoupledBaffleMix ed" even there's no fluid flow on either side (for solid-solid interfaces). I was able to run the case like that (with "kappa solidThermo"), and the results look reasonable; but I still feel a bit unsettling about the type name or whether there is a better bc type to use. Could any know-better user explain whether this is the correct way to set up my case? Thanks. James |
June 22, 2016, 02:27 |
Anton Kidess
Rep Power: 29 |
The name is a bit confusing, but you have the power to look into the code!
https://github.com/OpenFOAM/OpenFOAM...hScalarField.C You can see there is nothing specific to solid or liquid there. All it does is make sure the values and the fluxes on both sides of the patch are consistent.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
June 22, 2016, 09:28 |
James Feng
Rep Power: 12 |
Thank you, Anton. I guess this is the only type of bc to use for coupling interfaces with the chtMultiRegionFoam solver. I can see that you are very knowledgeable. Is there any other type choices (just wondering)?
If I want to simplify my model by just solving the heat conduction in multiregion solids (without solving the fluid flow part) and apply a heat flux bc at the solid-fluid interface with specified heat transfer coefficient h (such as h*(T-Ta) where Ta is a specified temperature in the fluid), what bc type should I use and how to set it in the T dict in 0/ ? |
[swak4Foam] mass conservation of solid phase violated when using groovyBC with twoPhaseEulerFoam | xpqiu | OpenFOAM Community Contributions | 8 | June 17, 2015 02:08 |
Weak MultiRegion Velocity Coupling | Christian86 | OpenFOAM Programming & Development | 0 | April 24, 2014 10:34 |
soild - solid coupling in CHT | stawrogin | OpenFOAM | 0 | May 17, 2011 15:42 |
coupling solid and fluid cells?? | kcg | Siemens | 4 | March 13, 2007 09:39 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
