March 7, 2016, 06:34 |
chtMultiRegionSimpleFoam 3D problem
Lucie
Rep Power: 10 |
I did a chtMultiRegionSimpleFoam case with radiation, convection and conduction between 4 solids and the air around. This model works fine in 2D with frontAndBack with "empty" condition, but when I did the same in 3D I have a problem. The calcul doesn't run ! There is only one iteration and only for displacement solver. The run stopped before h is calculated. Do you know where the problem could be? /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ /* Windows port by CFD support (www.cfdsupport.com) [based on Symscape] *\ \*---------------------------------------------------------------------------*/ Build : 2.3.x-819030ed51bd nProcs : 1 fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create fluid mesh for region domain0 for time = 0 Create solid mesh for region Solid1 for time = 0 Create solid mesh for region Solid2 for time = 0 Create solid mesh for region Solid3 for time = 0 Create solid mesh for region Solid4 for time = 0 *** Reading fluid mesh thermophysical properties for region domain0 Adding to thermoFluid Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Adding to rhoFluid Adding to UFluid Adding to phiFluid Adding to gFluid Adding to turbulence Selecting turbulence model type RASModel Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; sigmak 1; sigmaEps 1.3; Prt 1; } Adding to ghFluid Adding to ghfFluid Selecting radiationModel P1 Selecting absorptionEmissionModel constantAbsorptionEmission Selecting scatterModel none Selecting sootModel none Adding fvOptions No finite volume options present *** Reading solid mesh thermophysical properties for region Solid1 Adding to thermos Selecting thermodynamics package { type heSolidThermo; mixture pureMixture; transport constIso; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } Adding to radiations Selecting radiationModel opaqueSolid Selecting absorptionEmissionModel constantAbsorptionEmission Selecting scatterModel none Adding fvOptions No finite volume options present *** Reading solid mesh thermophysical properties for region Solid2 Adding to thermos Selecting thermodynamics package { type heSolidThermo; mixture pureMixture; transport constIso; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } Adding to radiations Selecting radiationModel opaqueSolid Selecting absorptionEmissionModel constantAbsorptionEmission Selecting scatterModel none Adding fvOptions No finite volume options present *** Reading solid mesh thermophysical properties for region Solid3 Adding to thermos Selecting thermodynamics package { type heSolidThermo; mixture pureMixture; transport constIso; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } Adding to radiations Selecting radiationModel opaqueSolid Selecting absorptionEmissionModel constantAbsorptionEmission Selecting scatterModel none Adding fvOptions No finite volume options present *** Reading solid mesh thermophysical properties for region Solid4 Adding to thermos Selecting thermodynamics package { type heSolidThermo; mixture pureMixture; transport constIso; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } Adding to radiations Selecting radiationModel opaqueSolid Selecting absorptionEmissionModel constantAbsorptionEmission Selecting scatterModel none Adding fvOptions No finite volume options present Time = 1 Solving for fluid region domain0 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.02938802, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.008910754, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.0291222, No Iterations 1 |
March 17, 2016, 15:39 |
Alex
Rep Power: 21 |
Hi Lucie,
You need to provide more information if you want to get some help from the forum. It is impossible to diagnose anything with the few information you gave us... You didn't even attach the error message!!! Information such as boundary conditions, fvSolution, error message shown by the solver is usually needed in order to be able to find out what is going wrong! Best regards, Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in! |
June 21, 2016, 05:23 |
Vishesh
Rep Power: 9 |
please provide with the error message.
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
