No outlet flow in porousSimpleFoam
Old   July 20, 2016, 10:08
Default No outlet flow in porousSimpleFoam
António Soares
Outbound is on a distinguished road
I'm having trouble simulating an open channel flow (with wall with slip condition standing for free surface) with porous medium in porousSimpleFoam because for some reason I get no outlet flow out of the outlet patch.
For some reason there is volumetric flow into the control volume but I don't understand with the outlet patch doesn't output any of the flow.
I've set up the case like so to try out the conditions as I was already having this problem with the actual compound channel flow mesh.
The porosity cellset indefined in blockMeshDict. What I'm not sure on is why no flow out of the CV through the outlet patch. I even tried adding a porosity free buffer zone after the porous cellset but after a few seconds it still seems like the boundary conditions are ill-defined.
I was able to run simple flow in a square channel in simpleFoam. Is it possible to add porosity to that simulation?
Thank you for any help you might provide.
Outbound is offline   Reply With Quote
Old   July 21, 2016, 13:16
António Soares
I should note that I switched the turbulence model from kEpsilon to kOmegaSST.
Is it possible that I've ill-defined the parameters for the boundary conditions for this model and that that's what's causing the blockage at the outlet patch?
Old   August 9, 2016, 12:06
António Soares
FYI, there seems to be a problem with porousSimpleFoam with porous cellsets parallel in flow direction to freeflow cellsets. The solver seems to take into account an extra patch which becomes undefined and which essentially blocks the flow.
It doesn't seem to be a problem in simpleFoam since the exact same mesh with the exact same boundary conditions seem to work fine in simpleFoam, with the porosity properties being defined in the fvOptions file.
Old   August 11, 2016, 06:51
António Soares
Ah, I've run into the same problem in simpleFOAM.
The fault seems to be that I'm not applying the kOmegaSST turbulence model correctly.
The flow seems to work fine with the realizableKEpsilon model, but as soon as I switch to kOmegaSST I get the same problem of the flow being impeded at the outlet.
Compressible Flow Pressure Outlet Back Flow okstatecheme OpenFOAM Running, Solving & CFD 1 March 21, 2018 08:11
Compressor Computation: Mass flow outlet and "Fatal Overflow in Linear Solver" ? jackzhushen CFX 5 June 25, 2015 18:15
Outlet BC for disturbed Poiseuille flow murx CFX 10 February 22, 2012 13:55
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
