SnappyHexMesh& extrudeMesh
Like Tree10Likes
Old   May 28, 2013, 12:17
Default SnappyHexMesh& extrudeMesh
s.m
saeideh mohamadi
s.m is on a distinguished road
hi dear fomers, i am working on multi element arifoils, i make the mesh using snappyHexMesh, then for using this mesh with simpleFoam i run "extrudeMesh"
my problem is the cprner of slat that is good till extrudeMesh didn't run.
i put the pictures before and after the extrudeMesh.
any body could help me?
thanks to all
s.m is offline   Reply With Quote
Old   May 29, 2013, 09:33
Nima Samkhaniani
nimasam is on a distinguished road
Dear saide
look at this post
i think if you add several layers around your airfoil, problem will be solved
on given post there are is a test case which may help you
s.m likes this.
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   June 2, 2013, 09:02
s.m
saeideh mohamadi
Originally Posted by nimasam View Post
Dear saide
look at this post
Hi Dear Nima,
i did what you said me, but i didn't get good results
i attach some pictures of the corners of the elements
Old   June 2, 2013, 10:32
Nima Samkhaniani
dear saide
1) whats wrong?
2) why just two layers?
s.m likes this.
Old   June 2, 2013, 11:12
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi Saideh
this error occurred when I run blockMesh on your snappyHexMesh file:
Create time
--> FOAM FATAL IO ERROR:
Cannot open include file "/home/ehsan/Desktop/airfoil_snappyHexMesh/system/forceCoeffs" while reading dictionary "/home/ehsan/Desktop/airfoil_snappyHexMesh/system/controlDict.functions"
file: /home/ehsan/Desktop/airfoil_snappyHexMesh/system/controlDict at line 49.
    From function functionEntries::includeEntry::includeEntry(dictionary& parentDict, Istream&)
    in file db/dictionary/functionEntries/includeEntry/includeEntry.C at line 120.
FOAM exiting
s.m likes this.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   June 2, 2013, 11:33
Nima Samkhaniani
Old   June 2, 2013, 11:39
Ehsan
dear Nima
be more patient please!
yes its related.
Saideh wanted me help her but I wasn't familiar with snappyHexMesh and the files she gave me displayed an error on blockMesh that I wrote and noticed her to her thread.
Old   June 2, 2013, 11:48
Nima Samkhaniani
Old   June 2, 2013, 11:56
Ehsan
I think its better to help her than trying to answer me.as I know your posts were irrelevant dear Nima.you didn't know whats the matter and unfortunately now persist on your mistake.its nice that people accept their mistakes than keep them!
anyway,please have a look into the error if you can so that I can help her by her case.
Old   June 2, 2013, 12:01
s.m
saeideh mohamadi
dear saide
1) whats wrong?
hi dear nima,
i think what's wrong are those cells that are in the corner of the slat. is it a good mesh for there?
Old   June 2, 2013, 12:04
Nima Samkhaniani
Originally Posted by immortality View Post
Hi Saideh
Create time
FOAM exiting
well answer is there: (read error carefully )
you can comment those forceDict from controlDict, it can not find it in your system folder
Old   June 2, 2013, 12:12
Nima Samkhaniani
Originally Posted by s.m View Post
hi dear nima,
why not but i suggest to increase it to forexample 5 layers and post results here , i guess it will improve
s.m likes this.
Old   June 2, 2013, 12:32
s.m
saeideh mohamadi
Hi Saideh
Create time
FOAM exiting
Hi Dear ehsan,
yes i forget to put the include function that i had been written in the controlDict of airfoil_snappyHexMesh folder. sorry.
here you are, these are the complete folders in the attachment.
thank you very much
Old   June 2, 2013, 12:37
s.m
saeideh mohamadi
Dear Nima,
i don't think so, but I’ll run the snappy with 5 layers now.
Old   June 2, 2013, 13:11
Ehsan
dear Saideh in doing this command:
surfaceFeatureExtract -includedAngle 150 -writeObj constant/triSurface/airfoil.stl airfoil
this error displayed:
Create time
Reading surfaceFeatureExtractDict
cannot open file
file: /home/ehsan/Desktop/airfoil_snappyHexMesh_modified/system/surfaceFeatureExtractDict at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 87.
FOAM exiting
ehsan@Ehsan-com:~/Desktop/airfoil_snappyHexMesh_modified$ surfaceFeatureExtract -includedAngle 150 -writeObj constant/triSurface/airfoil.stl airfoil
Usage: surfaceFeatureExtract [OPTIONS]
options:
  -case <dir>       specify alternate case directory, default is the cwd
  -dict <file>      read control dictionary from specified location
  -noFunctionObjects
                    do not execute functionObjects
  -srcDoc           display source code in browser
  -doc              display application documentation in browser
  -help             print the usage
extract and write surface features to file
Using: OpenFOAM-2.2.0 (see www.OpenFOAM.org)
Build: 2.2.0-b363e8d14789
--> FOAM FATAL ERROR:
Wrong number of arguments, expected 0 found 3
Invalid option: -writeObj
Invalid option: -includedAngle
FOAM exiting
I'm totally unfamiliar with snappyHexMesh commands if I have run it mistakenly.
s.m likes this.
Old   June 2, 2013, 13:31
s.m
saeideh mohamadi
Create time
cannot open file
FOAM exiting
options:
  -noFunctionObjects
FOAM exiting
Dear ehsan, thank you very much for your kind attention.
i put in the attachment the airfoil_snappyHexMesh_modified2 , please open the allrun in this folder, i write in it that you just should run blockMesh and after that snappyHexMesh in two steps as you see in the allrun.txt.
Old   June 2, 2013, 13:35
s.m
saeideh mohamadi
Dear Nima,
these pictures are the results of runningSHM with five layers..
Old   June 2, 2013, 13:59
Nima Samkhaniani
dear saide
check which side of 3D body, are you going to extrude?
are both sides (front and back) are the same?
s.m likes this.
Old   June 2, 2013, 15:47
Ehsan
you're welcome.Saideh it executes fine till extrudeMesh
I don't know why it doesn't open.I use OF 2.2.0
Create time
Create mesh for time = 0
cannot open file
file: /home/ehsan/Desktop/airfoil_simpleFoam/system/extrudeMeshDict at line 0.
FOAM exiting
s.m likes this.
Old   June 2, 2013, 16:41
s.m
saeideh mohamadi
Create time
cannot open file
FOAM exiting
Great! Dear ehsan as i write in the Allrun.txt
after finishing the 2th step of snappHexMesh you should go two the airfoil_simpleFoam_modified that i attach for you, in this folder you should execute "extrudeMesh", after fininshing extrudeMesh, i create polyMesh in the constant folder of airfoil_simpleFoam_modified.
p-s: before running the extrudeMesh in terminal,please copy the name of aifoil_snappyHexMesh_modified2 folder, and past it in front of (sourceCase "../(here)") in extrudeMeshDict. after that, execute extrudeMesh.by executing the extrudeMesh, it extrude the mesh that the name of it's folder have been written in front of sourceCase in extrudeMeshDict
tahnk you very much again
[mesh manipulation] extrudeMesh from STL Surface TRT OpenFOAM Meshing & Mesh Conversion 1 March 26, 2018 07:15
[mesh manipulation] Generating 3-D axisymmetric mesh using extrudeMesh martyn88 OpenFOAM Meshing & Mesh Conversion 17 June 21, 2017 19:42
extrudeMesh - odd behaviour grjmell OpenFOAM 0 September 20, 2011 08:41
extrudeMesh from patch Lodda OpenFOAM 4 August 15, 2011 10:35
BIG Problem in extrudeMesh! wind_fyp OpenFOAM 0 January 28, 2010 00:41
