Massflow or average velocity boundary condition
Old   November 18, 2011, 09:55
Question Massflow or average velocity boundary condition
Jan Willem Krijger
Sideshore is on a distinguished road
Hello
I'm trying to simulate a pipeflow with 2 inflow boundary conditions and 1 outflow boundary condition using simpleFoam.
I tried using a fixedValue boundary condition for the velocity at the outflow. But the simulation didn't converged and I got disturbances at the outflow. Which is expected because the flow is not uniform when it approaches the outflow boundary.
I would like to define the velocity with zeroGradient at the inflow and the massflow or average velocity at the outflow. And the pressure with fixedValue at the inflow and zeroGradient at the outflow.
How can I set the massflow or the average velocity at the outflow boundary?
Any suggestions are appreciated!!
Sideshore is offline   Reply With Quote
Old   November 18, 2011, 14:33
Assistant Moderator
Bernhard Gschaider
Originally Posted by Sideshore View Post
Hello
So you want a boundary condition that keeps the velocity at the outlet the same but only rescales it to satisfy the prescribed mass flow. I'm not aware of such a BC (which doesn't mean that there is none).
If I had to do such a thing I'd use groovyBC (basically using an expression for the value like "U*mfTarget/mfCurrent" - the two mfs being specified/calculated). Note that probably to get this stable you'll have to make it a bit more complicated: at least some kind of underrelaxation to avoid trouble during the startup-phase and you'll have to decide whether you allow backflow (because that would be accelerated by the scaling too). And of course there is the general problem of specifying the massflow at the outlet ....
Old   November 18, 2011, 19:20
Wouter van der Meer
wouter is on a distinguished road
hello,
If you have two inlets and one outlet. I think the best thing to do is set the two inlet velocities (fixed value). Calculate the velocities from the ratio of flows through the inlet and the area of the inlets by hand and let simpleFoam calculate the outlet flow, what being an incompressible steady state should result in the asked for massflow.
hope this helps
Wouter
wouter is offline   Reply With Quote
Old   November 21, 2011, 04:05
Jan Willem Krijger
Thank you both for your reply!
Ansys CFX does have a massflow boundary condition, could be a very nice addition to OPENFOAM!
GroovyBC sounds interesting! But as you said it might be a struggle to get a stable solution. I'm going to look into groovyBC thanks!
Prescribing the inflow velocity at both inlets does not give an accurate result. Because when you prescribe the inflow velocity normally you also prescribe the fixed pressure at the outlet. Therefore you end up with a pressure difference between both inlets. Which is not the case I would like to simulate.
Of course you could iterate between inlet velocities to end up with a similar pressure at both inlets.
Old   November 21, 2011, 12:50
Wouter van der Meer
hello Jan Willem,
Maybe you can use my suggestion as a stable start for the simulation with groovyBC
Best
Wouter
Old   August 10, 2016, 05:16
akidess's Avatar
Anton Kidess
I think the fixedMean boundary condition works nicely for such a case.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   September 27, 2016, 15:09
Default Conservation of momentum
Rizvi
mOHAMMAD SADIK is on a distinguished road
Hello i am trying to solve the same problem in Ansys fluent , how do i check if momentum is conserved?
mOHAMMAD SADIK is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
how can i give a boundary condition with pressure and velocity together akhenathon FLUENT 6 April 24, 2012 18:32
Robin boundary condition for the velocity fumiya OpenFOAM 4 June 17, 2011 02:58
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 11:32
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
