Compressible Flat Plate with coupled hydrodynamic/thermal boundary layer |
September 14, 2016, 14:45 |
Obad
Rep Power: 12 |
Hello, I'm new to OpenFoam and trying to solve the flow over a flat plate for already more than a week...
I want to calculate the compressible flow over a zero pressure gradient heated flat plate. I'm using the rhoCentralFoam solver and my boundary conditions are: velocity: fixed at inlet, no slip at wall, zero gradient for farfield and outlet pressure: fixed at inlet and outlet, zero gradient for farfield temperature: fixed at wall, fixed at farfield, zero gradient at inlet and outlet If I solve the problem without the heating of the flat plate I get a reasonable result for the hydrodynamic boundary layer. However, when I increase the plate temperature the results for the hydrodynamic BL are messed up and the temperature BL looks reasonable instead... Since flat plate flow is a standard problem I guess someone of you can help me Cheers! |
Developed turbulent boundary layer simulation on flat plate | Turbulent | CFX | 3 | June 8, 2015 19:46 |
Boundary Layer of Laminar Flow over a Flat Plate | Blasius_Pohlhausen_Crocco | Main CFD Forum | 12 | September 30, 2013 17:35 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
zero equation model for flat plate boundary layer | Amir | Main CFD Forum | 4 | June 18, 2008 11:16 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 13:20 |
