How can I load other objects like U or alpha1 when making a new boundary condition?
Like Tree2Likes
  • 2 Post By Jung hoo
Old   September 10, 2016, 14:48
Default How can I load other objects like U or alpha1 when making a new boundary condition?
Lee Jung Hoo
Jung hoo is on a distinguished road
Hi, I'm trying to create my own boundary condition.
I'm modifying the Member Function from parabolicVelocityFvPatchVectorField.C(i.e, I chose parabolicVelocityFvPatchVectorField.C as the base)
When I tried to read field values like U or p on the boundary function, compiling was successfully done, but I get the error message as belows when I run "setFields" on an example case based on interFoam.
--> FOAM Warning :
From function dlLibraryTableOpen(const fileName& functionLibName)
in file db/dlLibraryTable/dlLibraryTable.C at line 85
could not load /home/lee/foam/lee-3.1/lib/linux64GccDPOpt/libmyfunctionfinal2.so: undefined symbol: _ZTVN4Foam15twoPhaseMixtureE
And then, when I run application(interFoam), an error message is shown :
Reading field T
--> FOAM FATAL ERROR:
request for volVectorField U from objectRegistry region0 failed
available objects of type volVectorField are
1
T
From function objectRegistry::lookupObject<Type>(const word&) const
in file /home/lee/foam/foam-extend-3.1/src/foam/lnInclude/objectRegistryTemplates.C at line 139.
FOAM aborting
Aborted (core dumped)
I used these commans for reading the field values(U, phi, alpha1)
const volVectorField& U = db().lookupObject<volVectorField>("U");
const surfaceScalarField& phi = db().lookupObject<surfaceScalarField>("phi");
const volScalarField& alpha1 = db().lookupObject<volScalarField>("alpha1");
I'm beginner in programming, so I guess I'm missing a simple thing...
this is a part of Member Function:
void cbVelocityFvPatchVectorField::updateCoeffs()
if (updated())
return;
const fvMesh& mesh = dimensionedInternalField().mesh();
//const fvMesh& mesh = patch().boundaryMesh().mesh();
const word& patchName = this->patch().name();
const label patchID = mesh.boundaryMesh().findPatchID(patchName);
const volScalarField& alpha1 = db().lookupObject<volScalarField>(alphaName());
//volVectorField U("U", U);
//surfaceScalarField phi("phi", phi);
//volScalarField alpha1("alpha1", alpha1);
twoPhaseMixture twoPhaseProperties(U, phi, "alpha1");
autoPtr<incompressible::turbulenceModel> turbulence
incompressible::turbulenceModel::New(U, phi, twoPhaseProperties)
volSymmTensorField Reff(turbulence->devReff());
scalar rho = 1000;
scalar nu = 1e-06;
scalar mu = nu*rho;
scalar g = 9.81;
scalar s = 1.4;
scalar d = 0.005;
scalar shieldsc = 0.05;
scalar kappa = 0.8;
scalar c0 = 3;
//scalar Alpha1 = 0.8*mathematicalConstantPi;
scalar Alpha1 = 2;
scalarField wallShearStress = rho*mag((-mesh.Sf().boundaryField()[patchID]/mesh.magSf().boundaryField()[patchID]) & Reff.boundaryField()[patchID]);
scalarField shields = (wallShearStress)/(rho*(s-1)*g*d);
scalarField PEF = (pow((1+pow4((((1/6)*mathematicalConstantPi*mu)/(shields-shieldsc)))), -(1/4)));
scalarField linearC = sqrt(((sqr(kappa)*sqr(Alpha1))*(shields-shieldsc-((1/6)*mathematicalConstantPi*mu*PEF)))/(0.013*s*shields));
scalarField cb = c0/pow3((1+(1/linearC)));
vectorField n = patch().nf();
vectorFieldOperator=(-n*cb);
Any comments will help me a lot!
Thank you in advance!!
atulkjoy and Zhiheng Wang like this.
Jung hoo is offline   Reply With Quote
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 04:39
several fields modified by single boundary condition schröder OpenFOAM Programming & Development 3 April 21, 2015 05:09
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
