Fail timeVaryingMappedFixedValue
Old   November 16, 2015, 04:29
Question Fail timeVaryingMappedFixedValue
Zen
Zeno
Zen is on a distinguished road
Hi everyone,
I am using timeVaryingMappedFixedValue to set an inflow boundary condition at the inlet of a straight pipe. I have defined the velocity at the cell centres and put the 'points' and 'U' file in the corresponding directories under 'constant/boundaryData'.
Since I've specified the values of the velocity at the cell centres, there should be no interpolation. However, I can see some cells present wrong U values (see attached picture, close to the walls. The blue dots at the pipe centre are correct).
Does anyone know how I can solve this problem?
Thanks in advance,
Z
P.S. I am using of-2.4.0
Zen is offline   Reply With Quote
Old   November 16, 2015, 04:41
Default problem solved by using mapMethod nearest
Zen
Zeno
Problem solved.
I simply switched on the interpolation option 'mapMethod nearest' in the 0/U file.
I attached a picture for reference.
Old   December 14, 2016, 08:01
Default similar problem when forgetting to adapt "perturb" value
Aaron Endres
aendres is on a distinguished road
I had a similar problem in OpenFOAM 2.3.x with very fine grids, which was resolved by adding the entry
perturb 0.0;
in the boundary condition definition.
Just a brief remark for future forum readers...
aendres is offline   Reply With Quote
interpolation; error;
Eclipse for OpenFOAM AMahrla OpenFOAM Programming & Development 109 October 8, 2017 16:20
Fail to generate boundary condition profile data dotapro CFX 4 January 30, 2015 00:59
The fail of moving mesh liujmljm SU2 2 November 5, 2013 17:10
OpenMPI fail with Bluecape port of OF2.1 (I am doing it wrong). Doug68 OpenFOAM Installation 2 October 15, 2012 08:08
ITTC: Epic Validation Fail? Lysistrata Main CFD Forum 0 November 19, 2011 12:50
