preservepatches for cyclicAMI
Like Tree2Likes
Old   November 9, 2021, 08:47
sqek is on a distinguished road
Hello
Have you run topoSet since changing the actions in topoSetDict?
The names of the sets shouldn't cause an error, as long as they're the same in actions in topoSetDict as they are in singleProcessorFaceSets in decomposeParDict.
I'd suggest using the original names, as openFOAM sometimes automatically generates cellSets called region0, region1 etc, which would then get confused with the faceSets you're making
So put the original names in both topoSetDict and singleProcessorFaceSets,
then run topoSet (and look through the output - it should tell you the size of each set it makes, check that the number of faces in each is something reasonable)
If it's making too much output to easily read, run topoSet &>log.topoSet, then look at the log.topoSet file
then try decomposePar again
sqek is offline   Reply With Quote
Old   November 9, 2021, 09:44
Default works
  #22
qutadah
qutadah.r is on a distinguished road
So, thanks alot for the advices and hints! It finally works @sqek
here is how my files look like, for purposes of documentation for anyone who runs through this problem again
1- in topoSetDict i added:
actions
name INT_BLADE_1;
type faceSet;
action new;
source patchToFace;
sourceInfo
name "INT_BLADE_1-SIDE-1";
name INT_BLADE_1;
type faceSet;
action add;
source patchToFace;
sourceInfo
name "INT_BLADE_1-SIDE-2";
and so on for all my patches to gather them in sets like above....
2- in decomposeParDict i added:
constraints
        type singleProcessorFaceSets;
        singleProcessorFaceSets (
                (INT_BLADE_1 -1)
                (INT_BLADE_2 -1)
                (INT_BLADE_3 -1)
                (INT_BLADE_4 -1)
                (INT_BLADE_5 -1)
                (INT_BLADE_6 -1)
                (INT_IMP_VOL -1)
                (INT_SP_IMP -1)
        enabled true;
and then i ran topoSet and then decomposePar like said.
Thanks alot for your help!
qutadah.r is offline   Reply With Quote
cyclicami, preservepatches
CyclicAMI BC preservePatches Parallel Run - again!?! hxaxtma OpenFOAM Pre-Processing 4 August 31, 2015 18:47
The preservePatches Option in decomposePar Hisham OpenFOAM Pre-Processing 4 November 19, 2012 18:45
Cyclic patches and parallel postprocessing problems askjak OpenFOAM Bugs 18 October 27, 2010 04:35
