preservepatches for cyclicAMI
Like Tree2Likes
Old   December 13, 2016, 12:35
Default preservepatches for cyclicAMI
Jialin Su
ttjs3 is on a distinguished road
Hi Foamers,
I am using 2.4-0 at the moment. I am running a simulation that requires the use of the boundary condition "cyclicAMI". It's not possible to create the mesh in such a way that the matching patches have the same number of cells.
The single phase flow case runs no problem. But I also need to inject particles into the simulation as well. Then I ran into this problem:
--> FOAM FATAL ERROR:
Particle tracking across AMI patches is only currently supported for cases where the AMI patches reside on a single processor
From function void Foam::Cloud<ParticleType>::initCloud(const bool)
in file /work/y07/y07/cse/openfoam/2.4.0/build2/OpenFOAM-2.4.0/src/lagrangian/basic/lnInclude/Cloud.C at line 59.
FOAM parallel run aborting
So I presume I would need to preserve the patches that are "cyclicAMI". I added the following line in the decomposeParDict:
preserveFaceZones (SIDE1 SIDE2);
But this doesn't actually help to preserve the patches SIDE1 and SIDE2. They are still split into different processors. And the simulation still crashes with the same error message.
I looked up different threads here. But can't really find a solution. Is there any way to preserve the two "cyclicAMI" when decomposing the mesh? Or have I missed any other options in decomposePar?
I thought of using "simple". But I need to decompose a complex mesh into over 200 partitions. "simple" doesn't seem to apply here. Any suggestions will be really appreciated. Thank you in advance.
Best Regards,
Jialin Su
ttjs3 is offline   Reply With Quote
Old   December 14, 2016, 14:01
Jialin Su
I just realised that not just each individual cyclicAMI patch needs to be completely in the same processor for the simulation to run. Actually both patches (SIDE1 and SIDE2) need to be in one processor for the simulation to run.
Is there any way to instruct OpenFOAM to decompose in such a way? Thank you in advance.
Old   July 8, 2017, 15:30
Yousef
ykanani is on a distinguished road
Did you find the solution? I running into the same error. your parameters looks fine. PreservePatch should keep the cells in the same processor. I have done this thousands of times and it worked very well. But now I am facing this error with a particular grid. decomposition does not preserve patch.
ykanani is offline   Reply With Quote
Old   June 19, 2020, 13:08
Syavash Asgari
syavash is on a distinguished road
Originally Posted by ykanani View Post
Dear Yousef,
Same here. I wonder if there is a trick to force decomposePar to preserve patches. Did you find a solution?
Regards,
Syavash
syavash is offline   Reply With Quote
Old   June 19, 2020, 14:14
Ardalan
Ardali is on a distinguished road
Originally Posted by syavash View Post
Dear Yousef,
Regards,
Syavash
Please see the link below.
https://www.openfoam.com/documentati...-parallel.html
With adding constraints in decomposeParDict you can reach your intention.
Ardalan
Ardali is offline   Reply With Quote
Old   June 19, 2020, 14:34
Syavash Asgari
Originally Posted by Ardali View Post
Ardalan
Hi Ardalan,
Thanks for your response.
The issue is that despite using those constraints, my patch still gets splitted between multi processes.
The last option nonetheless looks promising, however I am using an older version of foam on cluster, so it's not really an option!
Please let me know if you had sth in mind.
Kind regards,
Syavash
Old   November 12, 2020, 04:14
Post cyclicAMI patches on the same processor
robt28 is on a distinguished road
I am currently using OpenFOAM 4.1 with a 3D axisymmetric geometry.
Using singleProcessorFaceSets dictionary in decomposeParDict
(front -1)
(back -1)
which is based on faces named "back" and "front" defined in /system/topoSetDict from the patches as :
actions
name front;
type faceSet;
action new;
source patchToFace;
sourceInfo
name "front";
name back;
type faceSet;
action new;
source patchToFace;
sourceInfo
name "back";
This tends to put all “front” and “back” cell faces so both cyclicAMI patches on the same processor.
However, this solution is not optimized regarding processor communications in my case.
I don’t have the solution to reach a fair decomposition of connected cell faces between processors with cyclic boundary conditions in OpenFOAM.
Best regards
robt28 is offline   Reply With Quote
Old   September 24, 2021, 14:53
Post
qutadah
qutadah.r is on a distinguished road
Ardalan
I have added as per link the following to my decomposeParDict
"""constraints
/ processors { type singleProcessorFaceSets; sets ((f1 -1)); enabled true; }
unfortunately i recieve the following error....
--> FOAM FATAL IO ERROR:
keyword singleProcessorFaceSets is undefined in dictionary "/hsmstorage/work/rababqjt/3D_Pump_SinglePhase/02_3D_Pumpe_M1_IncreasedGap_Qw68_CyclicAMI_SST_pim ple/system/decomposeParDict.constraints.processors"
file: /hsmstorage/work/rababqjt/3D_Pump_SinglePhase/02_3D_Pumpe_M1_IncreasedGap_Qw68_CyclicAMI_SST_pim ple/system/decomposeParDict.constraints.processors from line 49 to line 51.
From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
in file db/dictionary/dictionary.C at line 566.
FOAM exiting
what might be the issue? thanks
qutadah.r is offline   Reply With Quote
Old   September 24, 2021, 14:58
qutadah
I have tried your solution but get following error..
file: /hsmstorage/work/rababqjt/3D_Pump_SinglePhase/02_3D_Pumpe_M1_IncreasedGap_Qw68_CyclicAMI_SST_pim ple/system/decomposeParDict.constraints.processors from line 49 to line 53.
any suggestions??
i would also like to preserve cyclicAMI on same processor..
thanks!
Fouch likes this.
Old   October 11, 2021, 02:54
Fouch is on a distinguished road
Could you share your decomposeParDict ?
Best regards,
qutadah.r likes this.
Fouch is offline   Reply With Quote
Old   October 11, 2021, 09:37
Default decomposeParDict
  #11
qutadah
hier is attached my decomposeParDict
Old   October 11, 2021, 13:07
qutadah
here is my decomposeParDict !
Thanks for looking into it!
Old   October 11, 2021, 14:53
front and back are the names of the AMI patch.
replace these terms by INT_BLADE_2-SIDE-1 and INT_BLADE_2-SIDE-2and it should work.
Old   October 12, 2021, 07:28
qutadah
what does the front -1 mean? what is the 1 exactly?
in my case I have 16 AMI patches defined each as follows..
INT_IMP_VOL-SIDE-2
type cyclicAMI;
inGroups 1(cyclicAMI);
nFaces 35280;
startFace 14261224;
matchTolerance 0.0001;
transform coincidentFullMatch;
neighbourPatch INT_IMP_VOL-SIDE-1;
method faceAreaWeightAMI;
INT_SP_IMP-SIDE-1
type cyclicAMI;
nFaces 5020;
startFace 14296504;
neighbourPatch INT_SP_IMP-SIDE-2;
these were just two examples... I have entered them in the preserve patches as you suggested
processors
sets (
(INT_BLADE_1-SIDE-1 -1) //(f1 -1)
(INT_BLADE_1-SIDE-2 -1)
(INT_BLADE_2-SIDE-2 -1)
(INT_BLADE_3-SIDE-1 -1)
(INT_BLADE_3-SIDE-2 -1)
(INT_BLADE_4-SIDE-1 -1)
(INT_BLADE_4-SIDE-2 -1)
(INT_BLADE_5-SIDE-1 -1)
(INT_BLADE_5-SIDE-2 -1)
(INT_BLADE_6-SIDE-1 -1)
(INT_BLADE_6-SIDE-2 -1)
(INT_IMP_VOL-SIDE-1 -1)
(INT_IMP_VOL-SIDE-2 -1)
(INT_SP_IMP-SIDE-1 -1)
(INT_SP_IMP-SIDE-2 -1)
enabled true;
however im still recieving an error. any suggestion? thanks!
Old   October 12, 2021, 07:35
qutadah
I did as well change the topoSetDict as follows....
actions
name INT_BLADE_1-SIDE-1;
type faceSet;
action new;
source patchToFace;
sourceInfo
name "INT_BLADE_1-SIDE-1";
name INT_BLADE_1-SIDE-2;
type faceSet;
action new;
source patchToFace;
sourceInfo
name "INT_BLADE_1-SIDE-2";
is this correct? ofcourse for all the sets....
Old   October 28, 2021, 05:35
sqek is on a distinguished road
Hello
It would be helpful to say exactly what error you're getting and when
The number in a singleProcessorFaceSet constraint tells it which processor to put it on, -1 tells it to put it on any processor. So
( front 1 )
would put all faces in front, on processor 1, and
( front -1 )
would put all faces in front on the same processor, without caring which (this normally gives better decomposition as it can choose the best processor to put the faces on) (so it could be processor 0, processor 1, etc, whatever gives the best decomposition)
Assuming that the error you're getting is that it's still splitting the patches between processors:
It's probably because you're making a separate set for each side of each blade, so while all the faces in INT_BLADE_1-SIDE-1 are on the same processor, all the faces of INT_BLADE_1-SIDE-2 might be on a different processor.
You could fix this by putting both sides into the same faceSet, so
actions
name INT_BLADE_1;
type faceSet;
action new;
source patchToFace;
sourceInfo
name INT_BLADE_1;
type faceSet;
action add;
source patchToFace;
sourceInfo
This puts faces from patch INT_BLADE_1-SIDE-1 into set INT_BLADE_1, then adds the faces from patch INT_BLADE_1-SIDE-2 into the same set.
You'd then need
processors
sets (
(INT_BLADE_1 -1)
which makes sure all faces in set INT_BLADE_1 (so all the faces in INT_BLADE_1-SIDE-1 and INT_BLADE_1-SIDE-2) end up on the same processor
(There's also a potential issue you might run into if two of your patches are next to each other, sharing a point/cell: singleProcessorFaceSets actually takes all points of the faces of a faceSet, then all cells touching any of those points, then keeps those cells on the same processor, so nearby patches can end up forced to all be on the same processor - there's another thread on here about how to deal with that)
sqek is offline   Reply With Quote
Old   November 8, 2021, 18:00
Smile Foam fatal io error
  #17
qutadah
Thanks for the explanation, I have tried your method and still get the following error, which also states teh error is in the lines of my processor sets in the decomposeParDict....
keyword singleProcessorFaceSets is undefined in dictionary "/hsmstorage/work/rababqjt/3D_Pump_singlephase/02_3D_Pumpe_M1_IncreasedGap_Qw68_CyclicAMI_SST_pim ple/system/decomposeParDict.constraints.processors"
Do you have any suggestions? Thanks alot!
Old   November 9, 2021, 07:22
Hello
Having a look at the decomposeParDict in OpenFOAM-8 (the one I'm using), singleProcessorFaceSets looks like:
constraints
        singleProcessorFaceSets (
            ( set1 -1 )
            ( set2 -1 )
       ...more sets....
It looks like you've typed sets( instead of singleProcessorFaceSets( as the name of the list of sets - the error message you're getting says it's looking for an entry called "singleProcessorFaceSets" in the processors{ constraint you're setting up, so changing "sets" to "singleProcessorFaceSets" should fix that one
Old   November 9, 2021, 07:41
qutadah
I have tried doing that, it says following: I am using OF- version 6
unexpected class name cellSet expected faceSet
while reading object region0
file: /hsmstorage/work/rababqjt/3D_Pump_singlephase/02_3D_Pumpe_M1_IncreasedGap_Qw68_CyclicAMI_SST_pim ple/constant/polyMesh/sets/region0 at line 15.
From function Foam::Istream& Foam::regIOobject::readStream(const Foam::word&, bool)
in file db/regIOobject/regIOobjectRead.C at line 166.
the sets in the polymesh folder are of class cellSet... that seems to be the error.. Any idea how to fix this? Should i be adjusting the class of my sets to "faceSet" ?
Old   November 9, 2021, 07:42
qutadah
keep in mind i did adjust the set names to region0, region1, region2, because it gave me an error that INT_BLADE_1, ... is not found in sets ..... I believe the sets should be also defined...
cyclicami, preservepatches
CyclicAMI BC preservePatches Parallel Run - again!?! hxaxtma OpenFOAM Pre-Processing 4 August 31, 2015 17:47
The preservePatches Option in decomposePar Hisham OpenFOAM Pre-Processing 4 November 19, 2012 17:45
Cyclic patches and parallel postprocessing problems askjak OpenFOAM Bugs 18 October 27, 2010 03:35
