Utility deformedGeom destroys the mesh
Old   May 11, 2017, 03:24
Default Utility deformedGeom destroys the mesh
Peter
potentialFoam is on a distinguished road
Dear Foamers,
I would like to implement a displacement function for the mesh: Using the (funky-)setFields utility the displacement field should be specified and using e.g. the deformedGeom utility the mesh points should be moved.
Let's take a simple case first: a constant displacement field, e.g. U = (1 1 1) which should move the mesh by 1 in each direction. The problem is that the utility deformedGeom destroys the mesh! (edit: Happens with versions 3.0.1, 4.1 and 1606+.)
Case Example:
The following figure shows the geometry with the mesh:
Steps (the simple case is attached below as a zip-file):
1.) Create mesh (here using Snappy)
2.) Create displacement field U (using the setFields utility)
3.) Execute 'deformedGeom 1'
4.) checkMesh reports many errors -> the mesh is completely broken (high aspect ratio cells, negative volume cells, non-ortho erros, errors in face pyramids, high skewness)
You can download the case here
https://www.dropbox.com/sh/h5vgyuiif...rjrtIas0a?dl=0
Question: What's wrong there with deformedGeom?!
Regards,
Peter
potentialFoam is offline   Reply With Quote
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 15:15
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
