Using setFields and setWaves to set the required dataset |
April 21, 2020, 04:47 |
Rep Power: 14 |
I am simulating a floating tank containing water where it is affected by wave. To define the water inside the tank, one can use the setFields and to define the wave the possibility is using the setWaves tool. The thing is that using these two one after each other, clear the previous data set for U and alphaWater values. I wonder how to set these two data set without interrupting each other?
April 22, 2020, 04:05 |
#2 | |
Rep Power: 14 |
I found the solution and using swak4Foam and employing funkeySetfield tool sets the required fields. |
