[swak4Foam] how to write swakExpression
Old   June 7, 2017, 00:48
Default how to write swakExpression
harshawardhank
harsha_kulkarni is on a distinguished road
Hello Friends
I want to calculate mass transfer coefficient using swak4foam utility
formula for MTC is given by " (wallShearStress/U*896)*0.227"
value needed at the cell center
how to write using swakexpression using function object
harsha_kulkarni is offline   Reply With Quote
Old   June 7, 2017, 06:05
harshawardhank
MTC
type swakExpression;
expression "(wallShearStress/U*896)*0.227";
accumulations (sum);
valueType cellZone;
zoneName faceZone;
outputControlMode outputTime;
this is th function object I had used for calculating Mass Transfer Coefficient
after that I am getting error
[swak4Foam: Setting default mesh
[0]
[0]
[0] --> FOAM FATAL ERROR:
[0] The cellZone faceZone was not found in 0()
[0]
[0]
[0] From function getCellZoneID(const fvMesh &mesh,const word &name)
[0] in file CellZoneValueExpressionDriver.C at line 63.
[0]
FOAM parallel run exiting]
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
chtMultiRegionSimpleFoam does not write converged time step Tobi OpenFOAM Bugs 6 October 14, 2017 11:41
[Helyx OS] Helyx-OS (GUI for SnappyHexMesh elvis OpenFOAM Community Contributions 210 January 30, 2017 18:57
Floating point exception (yes...) sandri_92 OpenFOAM Running, Solving & CFD 0 October 23, 2016 14:42
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
