Boundary Condition for Far Field?
Like Tree2Likes
  • 2 Post By fletc900
Old   December 18, 2010, 13:45
Default Boundary Condition for Far Field?
Joris Peeters
Aneirin is on a distinguished road
I am trying to model the (subsonic compressible) flow over a moving object (like an airfoil). In Fluent, one can specify FarField boundary conditions, but I can not find something similar in OpenFOAM, at first glance (I looked through the source code for Derived Types, as mentioned in the Manual).
Has anyone succesfully completed such a simulation - and which boundary conditions did you use to do so? Details with regard to such simulations seem very scarce, I looked in numerous places.
Help would certainly be appreciated.
Aneirin is offline   Reply With Quote
Old   January 20, 2011, 16:49
Bruno F.
fletc900 is on a distinguished road
Hi there,
There is the "freestream" patch type. Take a look at the airfoil2D example under the simpleFoam directory for the tutorials that uses a c-mesh. In the 0/ directory, for the U file (and other variable files) , you should have something like:
boundaryField
inlet
type freestream;
freestreamValue uniform (43.71427 3.05657365 0); // angle of attack = 4 deg
outlet
type freestream;
wall
type fixedValue;
value uniform (0 0 0);
frontAndBack
type empty;
Cheers
kiddmax and BSengupta like this.
fletc900 is offline   Reply With Quote
Old   December 21, 2018, 21:12
Default Farfield BC in OpenFoam
Bidesh Sengupta
BSengupta is on a distinguished road
Hi, I am too new to OF. I have a spherical mesh in which a plate is placed which is made in Pointwise. I have two BC one is wall and the other is far field. I have written as below:
farfield
type freestream;
value uniform (48 95 27.5);
wall
type noSlip;
I am encountering the error:
"--> FOAM FATAL IO ERROR:
Cannot find patchField entry for inlet
file: /home/bidesh/OpenFOAM/bidesh-6/run/prism/0/p.boundaryField from line 26 to line 32.
From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam:imensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
in file /home/ubuntu/OpenFOAM/OpenFOAM-6/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 191.
FOAM exiting"
Any help shall be very helpful to me. Thank you.
BSengupta is offline   Reply With Quote
Old   August 31, 2021, 00:53
charan
charan3007 is on a distinguished road
did you your problem got solved cause i am also facing same issue
charan3007 is offline   Reply With Quote
Old   July 30, 2022, 03:49
Sakun
Sakun is on a distinguished road
Did you solve your issue ? i am having the same
Sakun is offline   Reply With Quote
Field value inside a boundary condition class pcaron OpenFOAM Programming & Development 14 October 17, 2022 09:40
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 12:26
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
The Boundary Condition about the Flat Plate boing Main CFD Forum 1 January 6, 2002 16:53
