Creating baffles in foam-extend
Like Tree1Likes
  • 1 Post By CFD-Henning
Old   May 15, 2017, 15:57
Default Creating baffles in foam-extend
MarcelK is on a distinguished road
I am currently working on a three-dimensional channel flow problem with a thin structure, which is finally intended to be integrated into an FSI simulation (that's why I need 0/motionU and constant/dynamicMeshDict).
The thin structure should be located at the face where block 0 and block 2 of my blockMeshDict intersect. Since the structure is very thin, I want to use createBaffles to convert internal faces into a boundary such that I am able to address the two sides of the thin structure separately (such that I am able to request pressure, for example, in the FSI calculation later on). My workflow for this is as follows:
m4 constant/polyMesh/blockMeshDict.m4 > constant/polyMesh/blockMeshDict
blockMesh
setSet -batch setBatch.batch
setsToZones
createBaffles fsBaffleLeft consoleLeft -overwrite
createBaffles fsBaffleRight consoleRight -overwrite
Apparently, the step to create the baffles does not work since the second invocation of createBaffles overwrites the result of the first invocation. Leaving the -overwrite option apart does not work either. My setBatch.batch file looks as follows:
faceSet fsBaffleLeft new cellToFace block0 all
faceSet fsBaffleLeft subset cellToFace block2 all
cellSet fsBaffleLeftMasterCells new cellToCell block0
faceSet fsBaffleRight new cellToFace block0 all
faceSet fsBaffleRight subset cellToFace block2 all
cellSet fsBaffleRightMasterCells new cellToCell block2
quit
When using the createBaffles tool in OpenFOAM, it is possible to specify a master and slave patch via a createBafflesDict. Unfortunately, I have not yet found an option in the createBaffles from foam-extend to do this. Any help on this would be much appreciated.
MarcelK is offline   Reply With Quote
Old   February 21, 2018, 12:05
Smile Creating interface in FE-4.0
CFD-Henning's Avatar
Henning Kuchenbuch
CFD-Henning is on a distinguished road
Hey Marcel,
did you solve the problem? I am sorry to come up as a thread necromancer, but I'm struggeling with the same problem.
I'm a foam-newbie and work also on a FSI-case (Foam-Extend 4.0). Thereby I want to analyze the heave-movement of a floating object in a wave tank. So I want to insert this object as a patch with a wall-bc into an internal part of the pre-meshed domain.
I went as following:
-Meshing with blockMesh
-define cellSet "c0" with the geometrie of the floating Object
-define a faceSet "interface_zone" out of c0 (just all sides)
-create cellZones
-replace pre-defined empty interface-patch with new patch (createBaffles interface_zone interface -overwrite)
Unfortunately this is not working, coming up with the following checkMesh-log
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    all points:           7007
    live points:          7007
    all faces:            17794
    live faces:           17794
    internal faces:       14606
    cells:                5400
    boundary patches:     6
    point zones:          0
    face zones:           1
    cell zones:           2
Overall number of cells of each type:
    hexahedra:     5400
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
   *Number of regions: 2
    The mesh has multiple regions which are not connected by any face.
  <<Writing region information to "0/cellToRegion"
Nuumber of cells per region:
    0    5340
    1    60
Checking patch topology for multiply connected surfaces ...
    Patch               Faces    Points   Area [m^2]  Surface topology
    inlet               60       77       0.6         ok (non-closed singly connected)
    outlet              60       77       0.6         ok (non-closed singly connected)
    bottom              900      1001     9           ok (non-closed singly connected)
    atmosphere          900      1001     9           ok (non-closed singly connected)
    frontBack           1080     1274     10.8        ok (non-closed singly connected)
    interface           188      96       1.88        multiply connected (shared edge)
  <<Writing 96 conflicting points to set nonManifoldPoints
Checking geometry...
    This is a 3-D mesh
    Overall domain bounding box (0 -0.4 0) (9 0.2 1)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Mesh (non-empty, non-wedge) dimensions 3
    Boundary openness (5.44142e-19 3.55216e-16 6.00188e-17) Threshold = 1e-06 OK.
    Max cell openness = 1.73472e-16 OK.
    Max aspect ratio = 1 OK.
    Minumum face area = 0.01. Maximum face area = 0.01.  Face area magnitudes OK.
    Min volume = 0.001. Max volume = 0.001.  Total volume = 5.4.  Cell volumes OK.
    Mesh non-orthogonality Max: 0 average: 0 Threshold = 70
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 2.51968e-12 OK.
Mesh OK.
End
The interface-patch switched from 0 to 188 faces, whereby the faceSet of the floating Object has got only the half of it - 94 faces. It seems that there are issues with the direction of the faces, as I didn't define a master- and a slave-side.
What am I doing wrong and how is the best-practice-way of getting this solved in foam-extend? Btw. do I have to go with subsetMesh?
I would be very happy if you, or anyone in the community could help me with this .
Thanks in advance,
Henning
the_ichthyologist likes this.
CFD-Henning is offline   Reply With Quote
blockmeshdict, createbaffles, foam-extend, internal faces, setset
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 04:20
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
