Boundary conditions for simulating an infinite duct? |
August 13, 2017, 12:46 |
Tom
Rep Power: 9 |
I am trying to simulate two infinitively long square ducts connected by a small gap. I would like to map the velocity and pressure from the outlet to the inlet, and raise the values of the pressure field by a flat value to drive the flow that way. Here is an image of my geometry: I'm uncertain what boundary condition would allow me to do so, as the list of standard boundary conditions is somewhat sparse on detail, and a Google search hasn't been very helpful either. Does anyone have a recommendation? Thank in advance. |
August 27, 2017, 02:34 |
Nima Samkhaniani
Rep Power: 24 |
if i understood your problem well, the fan boundary condition with cyclic in velocity and jump in pressure is an appropriate BC.
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
August 30, 2017, 20:43 |
#3 | |
Tom
Rep Power: 9 |
For instance - are the baffles used in TJunctionFan necessary for creating a Fan BC? How does one set up a Fan BC in icoFoam? |
August 31, 2017, 03:45 |
Nima Samkhaniani
Rep Power: 24 |
i guess you need to read more try with user-guide
the icoFoam and pimpleFoam are solvers Fan is a BC so Fan boundary condition can be applied on every solver. Also pimpleFoam does similar job as icoFoam, so i don't understand why you limit yourself to icoFoam.
CGNS Boundary conditions using SU2 | denzell | SU2 | 3 | July 9, 2018 05:58 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
