Probe Warning, Probe Does Not Work
Like Tree3Likes
  • 1 Post By wallace
  • 1 Post By wallace
  • 1 Post By alexeym
Old   October 4, 2013, 11:37
Default Probe Warning, Probe Does Not Work
guilha is on a distinguished road
Greetings people,
I am running a case, with parallel computing, and before the computations I got this warning message:
--> FOAM Warning :
    From function probes::read()
    in file probes/probes.C at line 71
    Did not find location (0.03 0.11 0) in any cell. Skipping location.
--> FOAM Warning :
    Did not find location (0.03 0.11125 0) in any cell. Skipping location.
--> FOAM Warning :
    Did not find location (0.03 0.1125 0) in any cell. Skipping location.
--> FOAM Warning :
    Did not find location (0.03 0.1225 0) in any cell. Skipping location.
--> FOAM Warning :
    Did not find location (0.04 0.12375 0) in any cell. Skipping location.
--> FOAM Warning :
    Did not find location (0.0475 0.1275 0) in any cell. Skipping location.
I did not got any error with the checkMesh, and as I checked the probes are not outside the domain. I read on other thread (I do not remember the link) that while decomposing it might appear some problems. So I run the case in a single processor, and got the same warning, but only in one probe, the warning message is:
--> FOAM Warning :
So, does anyone know what is the problem ?
Se Urso Vires Foge Tocando Gaita Para Hamburgo
guilha is offline   Reply With Quote
Old   October 5, 2013, 14:49
Nima Samkhaniani
nimasam is on a distinguished road
checkMesh and see whether your mesh is in domain or not
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   October 14, 2013, 07:04
As I said (and confirmed), the probes are in the domain. If I DO NOT decompose the problem, i. e. run the simulation in only one processor, OpenFOAM still gives me one warning. Is there any problems between decomposing the mesh and probe locations ? And why I get the warning, if the probe is in the domain ?
Old   April 10, 2014, 09:41
Wallace Green
wallace is on a distinguished road
rather than using a probe functionObject try a polyLine set where the original probeLocations are now the points.
wallace is offline   Reply With Quote
Old   April 10, 2014, 09:54
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
actually warning are self-explanatory
For example in the warning it tries to tell you that a probe (0.03 0.1225 0) is outside of the mesh. And surely if a probe is outside of the mesh, there's nothing to probe.
Check dimensions of the mesh, check where you put your probes. Try to put all the probes inside the mesh.
alexeym is offline   Reply With Quote
Old   April 10, 2014, 11:45
Wallace Green
sure alexeym, but I have noticed the probe functionObject having trouble locating points that are inside a mesh when running in parallel. There are slight differences in the implementation of the particular findCell() function for probes, polyLines, clouds, etc. and in my experience, there are some bugs.
M.W.G. likes this.
Old   April 10, 2014, 12:27
Alexey Matveichev
Oh, sorry, missed several messages.
Does the number of warnings depend on the decomposition (number of subdomains, decomposition method)? Maybe probes are on processor boundaries (though in this case another warning should be issued)?
I've looked though the implementation of findCell method and wasn't able to find anything that won't be working in parallel cases.
Old   April 11, 2014, 13:38
Wallace Green
I've attached a case where I noticed this happening. The controlDict has functionObjects that write out velocity and pressure at 120 locations inside the domain at each iteration, once using type probes from libsampling and once using type sets with polyLine. The polyLine method works fine, but the probes approach skips four locations. Just use Allrun - hopefully it's self-explanatory.
If you get to the bottom of that and are still motivated, check out http://www.openfoam.org/mantisbt/view.php?id=0001147 for a another sampling peculiarity.
Hemishmistry04 likes this.
Old   April 14, 2014, 03:38
Alexey Matveichev
unfortunately I wasn't able to reproduce the error, here is the output of the solver for the attached case:
Build  : 2.2.2-9739c53ec43f
Exec   : simpleFoam -parallel
SIMPLE: convergence criteria
    field p      tolerance 0.001
    field U      tolerance 0.0001
    field "(k|epsilon)"  tolerance 0.0001
Starting time loop
Reading set description:
    polyLine
Time = 1
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.0762530558, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.69705505, Final residual = 0.651831039, No Iterations 1000
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.0752473553, No Iterations 1
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.0835314711, No Iterations 2
time step continuity errors : sum local = 1.10938559e-16, global = -3.04128912e-18, cumulative = -3.04128912e-18
smoothSolver:  Solving for epsilon, Initial residual = 0.999999992, Final residual = 0.0309136051, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 0.999999991, Final residual = 0.0339960612, No Iterations 2
Old   April 16, 2014, 05:01
Wallace Green
thanks for trying that out. I noticed from your output log that you are running 2.2.2. I had been running 2.3.x. I've built 2.2.x again and tested the same case - my output is now just like yours - no errors. If you (or anyone else) have 2.3.x available, I'd be interested in how that works for you. In the meantime though, I'll submit a bug report when I have an opportunity.
Old   April 18, 2014, 16:03
Alexey Matveichev
I'd like to confirm that bug can be reproduced with 2.3.x.
There was certain changes in findCell algorithm between 2.2.2 and 2.3.x though I wasn't able yet to determine the reason why everything is OK under 2.2.2 and not OK under 2.3.x (though I guess the reason is tetrahedral cells near the probes as mainly the algorithm was changed for tetrahedral mesh).
Old   February 20, 2015, 06:48
Michael
allett02015 is on a distinguished road
hello!
I can also confirm the bug. I'm using version 2.3.0 and for a list of 45 points which clearly ly within the domain 8 are not found. If I use the sample application the same error accures. Did somebody find a solution for the problem?
allett02015 is offline   Reply With Quote
Old   September 5, 2017, 13:21
Mukul
mukul92 is on a distinguished road
Hi, I'm facing a similar issue in OpenFOAM 4.1. Did someone file a bug report?
mukul92 is offline   Reply With Quote
Old   September 19, 2017, 05:13
Michael
Hei hei I used also version 3.0+ and there I do not have any problems to find the probes
probe warning
How to use setField to create sphere sega OpenFOAM Pre-Processing 38 January 13, 2022 00:39
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 10:05
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 10:20
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
OpenFOAM14 for Mac OSX Darwin 104 gschaider OpenFOAM Installation 118 July 20, 2008 05:19
