sixDoFRigidBodyMotion with AMI in rotating system
Old   September 24, 2017, 07:30
Default sixDoFRigidBodyMotion with AMI in rotating system
Dae-young(Dan)
fhjkfhjk is on a distinguished road
Dear foamers,
I am trying to simulate a flow over a cylinder which is rotating with z-axis.
In this case, I set up the dynamicMeshDict and blockMesh as following.
dynamicMeshDict file is
|  \\    /   O peration     | Version:  2.3.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      dynamicMeshDict;
dynamicFvMesh   dynamicMotionSolverFvMesh;
motionSolverLibs (
            "libfvMotionSolvers.so"
            "libsixDoFRigidBodyMotion.so"
//solver displacementLaplacian;
solver            sixDoFRigidBodyMotion;
displacementLaplacianCoeffs
diffusivity uniform (cylinder);
sixDoFRigidBodyMotionCoeffs
        patches         (cylinder);
        innerDistance   1;
        outerDistance   4;
        centreOfMass    (0 0 0);
    momentOfInertia    (0.3333 0.3333 0.3333);
    mass            2;
    orientation
      1 0 0
      0 1 0
      0 0 1
    veloicity    (0 0 0);
    acceleration    (0 0 0);
    angularMomentum    (0 0 0);
    torque        (0 0 0);
    gravity        (0 0 0);
    rho             rhoInf;
    rhoInf          1;
    report        on;
    solver
        type CrankNicolson;
    constraints
     yLine
       sixDoFRigidBodyMotionConstraint point;
       centreOfRotation    (0 0 0);
    //   direction        (0 0 1);
       angular
           sixDoFRigidBodyMotionConstraint axis;
           axis                 (0 0 1);
           //centreOfRotation   (0 0 0);
           //direction          (0 1 0);
    restraints
     S1
       sixDoFRigidBodyMotionRestraint linearSpring;
          anchor        (0 0 0);
          refAttachmentPt    (0 0 0);
          stiffness        35.0919;
          damping        0;
          restLength    0;
     S3
      sixDoFRigidBodyMotionRestraint sphericalAngularDamper;
          coeff 0;
    patches         (wing);
    innerDistance   0.3;
    outerDistance   1;
    mass            22.9;
    centreOfMass    (0.4974612746 -0.01671895744 0.125);
    momentOfInertia (1.958864357 3.920839234 2.057121362);
    orientation
        0.9953705935 0.09611129781 0
        -0.09611129781 0.9953705935 0
        0 0 1
    angularMomentum (0 0 -2);
    g               (0 -9.81 0);
    rho             rhoInf;
    rhoInf          1;
    report          on;
    solver
        type symplectic;
    constraints
        yLine
            sixDoFRigidBodyMotionConstraint line;
            centreOfRotation    (0.25 0.007 0.125);
            direction           (0 1 0);
        zAxis
            axis                (0 0 1);
    restraints
        verticalSpring
            anchor          (0.25 0.007 0.125);
            refAttachmentPt (0.25 0.007 0.125);
            stiffness       4000;
            damping         2;
            restLength      0;
        axialSpring
            sixDoFRigidBodyMotionRestraint linearAxialAngularSpring;
            axis            (0 0 1);
            stiffness       700;
            damping         0.5;
            referenceOrientation $orientation;
momentOfInertia    (0.2917 0.2917 0.25);
    mass         2;
patches    (cylinder);
innerDistance    0;
outerDistance    4;
    orientation
      1 0 0
      0 1 0
      0 0 1
    veloicity    (0 0 0);
    torque        (0 0 0);
    gravity        (0 0 0);
    rhoName        rhoInf;
    rhoInf        1;
    report        on;
diffusivity inverseDistance (cylinder);
and this is a boundary file
|  \\    /   O peration     | Version:  4.1                                   |
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
11
    outlet
        type            patch;
        nFaces          240;
        startFace       210120;
    sym1
        type            patch;
        nFaces          360;
        startFace       210360;
    sym2
        type            patch;
        nFaces          360;
        startFace       210720;
    inlet
        type            patch;
        nFaces          240;
        startFace       211080;
    cylinder
        type            wall;
        inGroups        1(wall);
        nFaces          320;
        startFace       211320;
    back
        type            empty;
        inGroups        1(empty);
        nFaces          80000;
        startFace       211640;
    back-calulated
        type            empty;
        inGroups        1(empty);
        nFaces          25600;
        startFace       291640;
    front
        type            empty;
        inGroups        1(empty);
        nFaces          80000;
        startFace       317240;
    front-calculated
        type            empty;
        inGroups        1(empty);
        nFaces          25600;
        startFace       397240;
    AMI_master
        type            cyclicAMI;
        inGroups        1(cyclicAMI);
        nFaces          320;
        startFace       422840;
        matchTolerance  0.0001;
        transform       noOrdering;
        neighbourPatch  AMI_slave;
    AMI_slave
        type            cyclicAMI;
        nFaces          320;
        startFace       423160;
        neighbourPatch  AMI_master;
The body is rotated by a force induced by vortex sheds.
and I know I can rotate the mesh by applying omega in dynamicMesh, but in my case, I cannot use omega and it is calculated by the moment of inertia.
In this case, the mesh around body is morphed badly. As attached
I want to change it to rotate as a rigid body motion.
any suggestion for this problem I would be happy.
Thank you in advance.
fhjkfhjk is offline   Reply With Quote
Old   March 13, 2018, 15:20
David Balam
dbalamt is on a distinguished road
Maybe the wingMotion Tutorial can help you
dbalamt is offline   Reply With Quote
Free Fall Rotating Solid Object (layeradditionremoval + sixDoFRigidBodyMotion + AMI) chujeh2020 OpenFOAM 2 June 14, 2015 20:08
[snappyHexMesh] 2D AMI Moving Mesh with sHM; How hard can this be? ADGlassby OpenFOAM Meshing & Mesh Conversion 18 June 18, 2013 06:07
planetary hollow cylinder rotating system antonio FLUENT 1 March 9, 2007 13:35
Need ideas-fuel discharge system Jan FLUENT 1 October 10, 2006 23:05
Code with reliable free surface capability in a rotating system Subhasish Roy Choudhury Main CFD Forum 1 September 4, 1998 18:47
