How to have spatially varying inlet velocity profile for a multiphase flow |
September 28, 2017, 08:27 |
Ørjan Kvamme
Rep Power: 9 |
Hi folks,
Looking for input on how to set a spatially varying inlet velocity for example linear: U(y) = S*y The flow is multiphase (air, water), where the water part is the one that needs to have the spatially varying velocity. Preferably there is also a way to change the initial velocity in the water part as well, maybe by using the setFields utility and topoSet? |
October 4, 2017, 14:44 |
Thomas Evans
Rep Power: 10 |
The setFields utility can set cell values and/or face values. What you need here is face values on the inflow patch. This fragment from setFieldsDict should give you the idea.
defaultFieldValues ( volVectorFieldValue U (0.4 0 0) ); regions ( boxToFace { box (-1 -1 -30) (1 1201 -27.5); fieldValues ( volVectorFieldValue U (0.267863 0 0) ); } boxToFace { box (-1 -1 -27.5) (1 1201 -25); fieldValues ( volVectorFieldValue U (0.313519 0 0) ); } boxToFace { box (-1 -1 -25) (1 1201 -22.5); fieldValues ( volVectorFieldValue U (0.334759 0 0) ); } // ... more boxes ) Oops, I missed the part where you said ICs as well. Same idea, but use boxToCell with boxes that cover the required volumes. If making the variation smooth is crucial, you probably want to use funkySetFields. |
October 5, 2017, 05:42 |
Ørjan Kvamme
Rep Power: 9 |
Smooth variation is ideal, so I should try funkySetFields. Do you need to compile something to get funkySetFields to get it. It just says command not found when I try to execute.
I am currently running OpenFoam 5.0. |
October 5, 2017, 09:16 |
Thomas Evans
Rep Power: 10 |
funkySetFields is part of swak4foam -- https://openfoamwiki.net/index.php/Contrib/swak4Foam
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
UDF parbolic inlet velocity profile for 3D Ractangular channel flow. | srv537 | Fluent UDF and Scheme Programming | 4 | August 10, 2016 09:25 |
3D Velocity profile for turbulent flow | Kirill | Fluent UDF and Scheme Programming | 3 | July 17, 2014 08:42 |
How to define a fixed velocity for a given mass flow rate on inlet | mqasimali | FLUENT | 2 | April 12, 2013 17:24 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
