Tom
Rep Power: 9 ![]() |
I haven't done a URANS simulation before and i need some help please. I am looking at running rhoPimpleFoam. I have previously ran a rhoSimpleFoam simulation and understood that the setup for rhoPimple foam would be very similar with the exception that my system directory would be different. I am planning on copying openfoam5/tutorials/compressible/rhoPimpleFoam/RAS/cavity/system . Is there anything that you think i need to modify apart from the deltaT in my control dict? How do i chose an appropriate deltaT? I understood that it related to cellsize and courant number...but how do i find out my cell size? Are there any good videos on rhoPimpleFoam? Kind regards, Tom |
Fridrik Magnusson
Rep Power: 8 ![]() |
Hi Tom
I just started working with rhoPimpleFoam and would like to share my limited knowledge. When I select a deltaT, i just make a guestimate and iterate to make sure the Courant number is less than 1 (eventhough the pimple algorithm should be able to handle Co > 1). The correct way to get deltaT is to use: ![]() for more dimension http://https://en.wikipedia.org/wiki...Lewy_condition maybe you can see the see a magnitude of the size of your grid in constant/polyMesh/points. - Fridrik Magnusson |
Rep Power: 12 ![]() |
Hi Tom
was using pimpleFOAM once. This will help you. https://openfoamwiki.net/index.php/O...hm_in_OpenFOAM |
rhoPimpleFoam Boundary Condition Problem | dancfd | OpenFOAM Pre-Processing | 18 | September 16, 2021 07:43 |
rhoPimpleFoam solver | adrieno | OpenFOAM Running, Solving & CFD | 11 | April 6, 2016 11:01 |
Pressure stair-step behaviour using rhopimplefoam | joegi.geo | OpenFOAM Running, Solving & CFD | 3 | December 12, 2014 12:10 |
rhoPimpleFoam floating point error | dancfd | OpenFOAM Running, Solving & CFD | 6 | January 5, 2014 20:57 |
Questions about buoyantPimpleFoam and rhoPimpleFoam | Mojtaba.a | OpenFOAM Running, Solving & CFD | 6 | August 1, 2012 04:50 |
