FOAM FATAL ERROR: Unable to find initial target face |
October 27, 2020, 11:06 |
ESI
Rep Power: 8 |
Dear Foamer,
Now, I am facing the issue with OpenFOAM extent 4.0 Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object createPatchDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // This application/dictionary controls: // - optional: create new patches from boundary faces (either given as // a set of patches or as a faceSet) // - always: order faces on coupled patches such that they are opposite. This // is done for all coupled faces, not just for any patches created. // - optional: synchronise points on coupled patches. // - always: remove zero-sized (non-coupled) patches (that were not added) // 1. Create cyclic: // - specify where the faces should come from // - specify the type of cyclic. If a rotational specify the rotationAxis // and centre to make matching easier // - always create both halves in one invocation with correct 'neighbourPatch' // setting. // - optionally pointSync true to guarantee points to line up. // 2. Correct incorrect cyclic: // This will usually fail upon loading: // "face 0 area does not match neighbour 2 by 0.0100005%" // " -- possible face ordering problem." // - in polyMesh/boundary file: // - loosen matchTolerance of all cyclics to get case to load // - or change patch type from 'cyclic' to 'patch' // and regenerate cyclic as above matchTolerance 0.001; // Do a synchronisation of coupled points after creation of any patches. // Note: this does not work with points that are on multiple coupled patches // with transformations (i.e. cyclics). pointSync true; // Optional: Write cyclic matches into .obj format; defaults to false. //writeCyclicMatch false; // Patches to create. patches ( { // Name of new patch name inlet; // Dictionary to construct new patch from patchInfo { type cyclicAMI; transform translational; neighbourPatch outlet; separation (-8.743006318923108e-15 0.8999999999999797 -1.315614284180811e-14); } // How to construct: either from 'patches' or 'set' constructFrom patches; // If constructFrom = patches : names of patches. Wildcards allowed. patches (Inlet); // If constructFrom = set : name of faceSet set f0; } { // Name of new patch name outlet; // Dictionary to construct new patch from patchInfo { type cyclicAMI; transform translational; neighbourPatch inlet; separation (8.743006318923108e-15 -0.8999999999999797 1.315614284180811e-14); } // How to construct: either from 'patches' or 'set' constructFrom patches; // If constructFrom = patches : names of patches. Wildcards allowed. patches (Outlet); // If constructFrom = set : name of faceSet set f0; } { name left; patchInfo { type cyclicAMI; transform translational; neighbourPatch right; separation (4.024558464266192e-15 -8.43769498715119e-15 0.4499999999999016); } constructFrom patches; patches (Left); set f0; } { name right; patchInfo { type cyclicAMI; transform translational; neighbourPatch left; separation (-4.024558464266192e-15 8.43769498715119e-15 -0.4499999999999016); } constructFrom patches; patches (Right); set f0; } ); // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 7 ( Top { type wall; inGroups List<word> 1(wall); nFaces 16384; startFace 6569344; } Ridges { type wall; inGroups List<word> 1(wall); nFaces 8192; startFace 6585728; } Wall_below { type wall; inGroups List<word> 1(wall); nFaces 36864; startFace 6593920; } inlet { type cyclicAMI; inGroups List<word> 1(cyclicAMI); nFaces 17280; startFace 6630784; matchTolerance 0.0001; neighbourPatch outlet; transformType translational; separation (-8.743006318923108e-18 0.0008999999999999797 -1.315614284180811e-17); method faceAreaWeightAMI; } outlet { type cyclicAMI; inGroups List<word> 1(cyclicAMI); nFaces 17280; startFace 6648064; matchTolerance 0.0001; neighbourPatch inlet; transformType translational; separation (8.743006318923108e-18 -0.0008999999999999797 1.315614284180811e-17); method faceAreaWeightAMI; } left { type cyclicAMI; inGroups List<word> 1(cyclicAMI); nFaces 18176; startFace 6665344; matchTolerance 0.0001; neighbourPatch right; transformType translational; separation (4.024558464266192e-18 -8.43769498715119e-18 0.0004499999999999016); method faceAreaWeightAMI; } right { type cyclicAMI; inGroups List<word> 1(cyclicAMI); nFaces 18176; startFace 6683520; matchTolerance 0.0001; neighbourPatch left; transformType translational; separation (-4.024558464266192e-18 8.43769498715119e-18 -0.0004499999999999016); method faceAreaWeightAMI; } ) // ************************************************************************* // I am trying to run on the Openfoam v8.0 that it is well working. But when I run it on the Openfoam extent 4.0 then I get the error as the above code. So How to fix it for this issue in Openfoam extent 4.0 ? Thank you for your help! |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
