July 20, 2015, 08:50 |
Viscous Layers generating defaultFaces
#1 | |
James F.
Rep Power: 9 |
Hi Foamers,
I have a problem with Salome/OpenFoam. There is a viscous layer in my current mesh and it is generating a problem once I export it to UNV to use it in OpenFoam later: the viscous layer is generating a face which is identified when I export to OpenFoam and create a defaultFace I cannot get rid off. (I first had this defaultFace poping, I went on paraFoam to see it and it was a face 3mm above my actual wall corresponding to the last viscous layer...) Does anyone has an idea on how to handle this problem? It never appeared before... Thanks :') EDIT: The ideasUnvToFoam command is telling me at the end: Quote:
EDIT2: checkMesh is telling me there are two regions in my mesh which is not normal. I should probably try to merge these two regions into one. Somehow... EDIT3: Everything is fine as long as I remove the viscous layers. |
July 20, 2015, 09:46 |
James F.
Rep Power: 9 |
"Solved" my problem by computing the mesh again... It was a bug I guess.
July 23, 2015, 05:09 |
James F.
Rep Power: 9 |
Well, I changed some parameters in my mesh to improve my computation but the problem is coming back and I cannot get ride off it by simply computing the mesh again and again... Any idea to fix my problem properly?
February 2, 2016, 05:04 |
Christof Schmidt
Rep Power: 10 |
I have exactly the same problem. I donīt know how to solve that. Could you find a way to handle it in the meantime? |
June 21, 2018, 05:49 |
Deep
Rep Power: 8 |
@NoradFirst2 or @cristopf were you able to solve this?
[ICEM] Prism layers distorted near trailing edge of blade-Unstructured Mesh | Rohith Giridhar | ANSYS Meshing & Geometry | 3 | June 29, 2015 17:52 |
run Doxygen offline | anishtain4 | OpenFOAM | 8 | November 27, 2014 09:36 |
Doxygen documentation | Tanay | OpenFOAM Installation | 9 | September 23, 2011 11:40 |
ParaView and Qt 4.3.5 on Mac OS X 10.6 | Adrian | OpenFOAM | 3 | August 8, 2010 03:16 |
TGRID- Problem in generating Viscous Mesh | abhinit | FLUENT | 3 | January 8, 2007 08:48 |
