Rep Power: 9 ![]() |
I want to use the turbulentInlet boundary Condition. I have found an example in the tutorials: Code:
inlet { type turbulentInlet; referenceField uniform (10 0 0); fluctuationScale (0.02 0.01 0.01); value uniform (10 0 0); } 2/3 k = 1/3 * (ux'²+ux'²+uz'²) and lets say ux'²=uy'²=uz'² I get k from: k=3/2 * (U*I)² , where I is the turbulent intensity. Greetings, Friendly |
Tobias Holzmann
Rep Power: 52 ![]() ![]() ![]() |
you can find the information in the source code. Explicitly in the header file. You find the location after going to the source of FOAM files and do something like that: Code:
shorty@src: find -iname "turbulentInlet" ./finiteVolume/fields/fvPatchFields/derived/turbulentInlet Code:
Description This boundary condition generates a fluctuating inlet condition by adding a random component to a reference (mean) field. \f[ x_p = (1 - \alpha) x_p^{n-1} + \alpha (x_{ref} + s C_{RMS} x_{ref}) \f] where \vartable x_p | patch values x_{ref} | reference patch values n | time level \alpha | fraction of new random component added to previous time value C_{RMS} | RMS coefficient s | fluctuation scale \endvartable Usage \table Property | Description | Required | Default value fluctuationScale | RMS fluctuation scale (fraction of mean) | yes | referenceField | reference (mean) field | yes | alpha | fraction of new random component added to previous| no| 0.1 \endtable Example of the boundary condition specification: \verbatim <patchName> { type turbulentInlet; fluctuationScale 0.1; referenceField uniform 10; alpha 0.1; } \endverbatim The value is normally just a dummy and is replaced in subsequent evaluations. Everything else is self-explaining by the above code or in the link.
Keep foaming, Tobias Holzmann |
thank your very much! I have a remaining short questions: What is meant by c_RMS and which value is defined? (RMS for Root Mean Square?). Is there somehow a pseudo random algorithm implemented in c_RMS? Alpha adds a fraction of a random component and I dont see anything else which could be random. |
Tobias Holzmann
See C++ code. However, I guess this boundary condition is useful for DNS simulations and not for RANS - maybe LES? I am not a turbulent expert.
template<class Type> void Foam::turbulentInletFvPatchField<Type>::updateCoeffs() { if (this->updated()) { return; } if (curTimeIndex_ != this->db().time().timeIndex()) { Field<Type>& patchField = *this; Field<Type> randomField(this->size()); forAll(patchField, facei) { ranGen_.randomise(randomField[facei]); } // Correction-factor to compensate for the loss of RMS fluctuation // due to the temporal correlation introduced by the alpha parameter. scalar rmsCorr = sqrt(12*(2*alpha_ - sqr(alpha_)))/alpha_; patchField = (1 - alpha_)*patchField + alpha_* ( referenceField_ + rmsCorr*cmptMultiply ( randomField - 0.5*pTraits<Type>::one, fluctuationScale_ )*mag(referenceField_) ); curTimeIndex_ = this->db().time().timeIndex(); } fixedValueFvPatchField<Type>::updateCoeffs(); }
OK I see there is a random generator, thanks again.
Yes, I want to use it for LES. But what about my calculation to determine the fluctuation scale? I still dont know what excactly is meant by fluctuation scale. The describtion does not help me. |
Saeed Jamshidi
Rep Power: 8 ![]() |
Dear Friendly, I hope this message finds you well.
Have you found your answers about fluctuation scale for turbulent inlet? I appreciate it if you share your experience at this matter. Thanks. |
Display Modes | |
Fully developed flow as inlet condition | Gemmatrix | STAR-CCM+ | 1 | December 6, 2016 05:02 |
To change temperature in mass flow inlet boundary condition per iteration | ajinkya201991 | FLUENT | 1 | July 11, 2014 12:29 |
Total pressure boundary condition at inlet:how to sustain inlet pressure in cfx | faizan | CFX | 10 | March 18, 2014 17:47 |
boundary condition for coupled inlet and outlet | xxxx | OpenFOAM Pre-Processing | 2 | August 13, 2013 16:51 |
How to use a solution as an inlet boundary condition in another problem in fluent | geryes | FLUENT | 0 | February 25, 2010 17:32 |
