February 26, 2018, 10:29 |
Cylinder flow Mesh
Çağatay Emre Ayhan
Rep Power: 8 |
Hello dear foamers,
I am studying a mesh in order to solve flow around a cylinder at Reynolds 100. When I compare my vortex shedding frequency with the value in the literature I get 5 percent error. Error due to drag coefficient is 8 percent. I need to decrease these error. I think its because of mesh. How can I avoid these types of shape of mesh? I have 90,000 cells. My setup folders are attached. Any help will be appreciated. I used snappyHex, extrudeMesh, topoSet and refineMeshDict in order to generate a 2D mesh with less computational cost. Thank you very much |
March 4, 2018, 15:06 |
#2 | |
Canakkale Dardanelspor
Rep Power: 13 |
Last edited by HakikiCanakkaleli; March 5, 2018 at 06:43. Reason: more kindly writing |
March 7, 2018, 14:22 |
Mark
Rep Power: 8 |
I recommend you to try open source mesh generation program GMSH. Its quite straightforward to use and you can easily define your cell spacing and refinemet factors.
FLow past cylinder. Mesh independency test | beattacz | FLUENT | 6 | April 26, 2020 15:44 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
flow around a cylinder | pXYZ | Main CFD Forum | 14 | July 25, 2011 10:05 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
