Mass source term in chtMultiRegionFoam
Like Tree3Likes
  • 3 Post By Researcher23
Old   November 29, 2018, 04:35
Default Mass source term in chtMultiRegionFoam
Researcher23 is on a distinguished road
Hi all,
I would like to introduce a mass source in the fluid part of chtMultiRegionFoam. My first try was to introduce a semiImplicitSouce:
|  \\    /   O peration     | Version:  5                                     |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      fvOptions;
scalarSource
    type            scalarSemiImplicitSource;
    duration        1000.0;
    selectionMode   all;
    volumeMode      absolute;
    injectionRateSuSp
        rho           (-0.1 0);
My problem is, that rho does not change with this source. Another try was a scalarCodedSource, with the same negative result: rho does not change in my fluid volume!
It is possible to change other fields (energy,...) with this kind of source, but I am interested in changing the masses.
Please could you give me a hint what's going wrong and how can I change rho in chtMultiRegionFoam?
Thanks a lot,
J.
Researcher23 is offline   Reply With Quote
Old   December 4, 2018, 03:22
Did somebody have an answer to my question?
Old   December 7, 2018, 04:13
Okay, I solved the problem. The bug (or missing feature) was that there is no fvOptions-term in the pressure equation of chtMultiRegionFoam. With adding this missing term my fvOptions mass term works fine. Here is our code fix:
        fvScalarMatrix p_rghEqn
            p_rghEqnComp + p_rghEqnIncomp
          + fvOptions(psi, p_rgh, rho.name())
Old   January 18, 2019, 07:42
Joachim Herb
jherb is on a distinguished road
Included in OpenFOAM-dev branch with https://bugs.openfoam.org/view.php?id=3146
jherb is offline   Reply With Quote
chtmultiregionfoam, mass source term
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 08:06
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
