January 17, 2019, 16:27 |
Boundary-Condition for k-epsilon model
I have a newbie question. I set up a simulation for flow through a pipe using a k-epsilon turbulence model. My wall boundary condition for U is a no-slip: wall: U: fixed Value (uniform (0 0 0)) I am using wall functions for k, epsilon and nut and I get a velocity profile that goes down to 0 at the walls. When I do the same simulation with Comsol Multiphysics using a k-epsilon model and wall functions, I get a velocity profile that is non-zero at the walls. This is explained because wall-functions model the flow only to the beginning of the buffer-layer. My question now is: what is the right way to do it in OpenFoam? Shouldn't the velocity at the walls also be non-zero when using wall functions? Thanks in Advance! |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
CFX fails to calculate a diffuser pipe flow | shenying0710 | CFX | 7 | March 26, 2013 04:13 |
