September 26, 2018, 07:01 |
flowRateOutletVelocity
Rep Power: 11 |
normally, we impose velocity at inlet and pressure at outlet. If I want to use flowRateOutletVelocity at outlets, what should be for an inlet? zeroGradient? What I should impose for pressure at inlet and outlets? All patches are zeroGradient ? But this doesn't work.... Any suggestions ? Thanks. |
October 18, 2018, 04:05 |
Rep Power: 15 |
Hi Svensen,
zeroGradient for the inlet velocity might be okay, you could also try pressureInletOutletVelocity. For the pressure you should then set a fixedValue at the inlet. |
October 18, 2018, 04:18 |
Rep Power: 11 |
I only know inlet flow rate and outlet flow rates.
For inlet, I could not set a pressure level, since it is varying during time. For outlet I could set only zero pressure level. But I think it is not sufficient. inlet: Code:
u - inlet flow rate; p - zero gradient; Code:
u - outlet flow rate; p - 0; |
October 24, 2018, 04:53 |
Rep Power: 15 |
You should provide some kind of fixed velocity value (whatever name the BC has) at one boundary, be it inlet or outlet. The other one should be zero gradient. For example:
Inlet: U --> zeroGradient; p --> fixedValue; Outlet: U --> flowRateOutletVelocity; p --> zero Gradient Is your flow incompressible or compressible? Last edited by oswald; October 24, 2018 at 04:53. Reason: formatting |
April 28, 2019, 16:39 |
#5 | |
When it come to incompressible fluids, it is comperatively easy to identify BC's since volumetric flow rate come in handy anyway. |
