May 12, 2017, 05:41 |
Fix Reynolds Number in a periodic flow
Chus Mat
Rep Power: 9 |
Hello to everyone,
I am trying to emulate the flow through periodic hills. Here is the case: http://qnet-ercoftac.cfms.org.uk/w/i...3-30_Test_Case But I am testing the effect of RANS simulations (k-omega and k-omegaSST) in these flow condition, using the solver simpleFoam in a 2D case. To solve the case I am applying cyclic BC on the inlet and the outlet of the flow, without convergence problems. However, I need to fix a Reynolds value to my simulation, with the reference velocity equal to the average velocity on the top of the second hill. I am having problems to fix this value with the cyclic BC. When I initialize my internal field the final values diverge from the Reynolds Number I want to my case. Any idea of how could I fix my average outlet velocity profile and then the Reynolds number with this Cyclic BC. Or how I should initialize better the internal field. I have tried to simulate the flow as non-periodic Hill with the velocity profile of the experimental data of the reference in the inlet, and then map the fields to my Cyclic BC case. I have also tried to initialize the fields with a uniform value. Any ideas of what should I do? Thank you for your help. |
May 12, 2017, 06:00 |
Uwe Pilz
Rep Power: 15 |
I don't know how you tried to set the Re number. It is mostly best to change the viscosity rather than the velocity.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
May 12, 2017, 06:05 |
Chus Mat
Rep Power: 9 |
Thank you for your answer
Yes I have already try to set the viscosity to fix the Reynolds of my initial field. But the problem is that in the final field the velocity profile changes, changing then the value of the Reynolds Number according to the case criteria. If exist a possibility of modifying dynamically the viscosity instead the velocity field, I will also like to know it. Please. The main intention of this thread is try to find a way to fix the Reynolds number in the periodic simulation. Any ideas? |
May 12, 2017, 06:06 |
Chus Mat
Rep Power: 9 |
May 12, 2017, 10:15 |
#5 | |
Uwe Pilz
Rep Power: 15 |
His law of similarity may be used for quite a lot (nearly all?) problems, of course. But you have to *define*, what the Reynolds-like number in your case should be. If the viscosity is constant, you need a characteristic length and a characteristic velocity for that. If the geometry is similar in mathematical sense you may select any of the length measures for analysis of changing. As you mentioned, the selection of a characteristic velocity may be harder. I don't understand your problem in full extend, and don't know where and under which circumstances the velocity changes. Often used values are the free stream velocity o the inlet velocity at pipe and channel streams. You have to select on velocity which fits your model. It may be, that you "see" this velocity first after you finished your simulation. This is not a problem per se. The only flaw is that you don't have round values lik Re=1000 but have to live with something like Re=973 or Re=1059.
May 13, 2017, 03:10 |
Ertan Demir
Sent from my GM 5 Plus d using CFD Online Forum mobile app
May 16, 2017, 03:56 |
Agustín Villa
Rep Power: 15 |
Hi
did you try the fvOption meanVelocityForce? There you can fix the mean value of the velocity of your flow. |
May 8, 2018, 01:41 |
Implementing cyclic (translational) boundary condition in OpenFOAM
HK
Rep Power: 10 |
There are two ways in which we can run translational periodic boundary condition cases. (Read this)
This can be implemented by using fvOption utility meanVelocityForce. Please go through channel395 tutorial for more details regarding implemention of above mentioned method. Last edited by Luttappy; May 25, 2018 at 01:13. |
June 12, 2019, 01:34 |
#9 | |
Satyajit Choudhury
Rep Power: 9 |
June 12, 2019, 01:45 |
#10 |
Agustín Villa
Rep Power: 15 |
please check the semiImplicitSource https://github.com/OpenFOAM/OpenFOAM...ImplicitSource There, just use the explicit term for adding the pressure gradient, if I remember well> U ( (dpdx dpdy dpdz) 0) Please take a look to the sign of the gradient, otherwise your flow will be oriented in the other sense. |
June 12, 2019, 02:08 |
#11 | |
Satyajit Choudhury
Rep Power: 9 |
cyclic boundary condition, periodic bc, reynolds number, simple foam, two dimensional model |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
About the Reynolds Number and Y-plus in external flow | Mason liu | CFX | 18 | November 10, 2014 18:37 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
High Reynolds Number Incompressible Flow | Nick Lavery | Main CFD Forum | 3 | February 19, 2002 15:47 |
Difficulties in solving a high Reynolds number Flow? | wowakai | Main CFD Forum | 10 | December 29, 1998 13:46 |
