k and omega initial value in 0 directory
Like Tree1Likes
  • 1 Post By geth03
Old   August 5, 2019, 09:24
Default k and omega initial value in 0 directory
Febrian Akhmad Baehaqi
febrianbaehaqi is on a distinguished road
Hi guys. I need some help.
Currently I am running a simulation on a UAV MALE and using simpleFoam as the solver. The Reynolds Number is about 2e+06.
I am a bit confused about how I set the initial value of the k and Omega in the 0 directory. When I read the previous forum someone said that the initial value of k and Omega is independent from the solution or the initial value of k and omega does not affect the results. But when I set a different initial value of k and Omega I keep getting different values of Cl and Cd.
I have already tried to compute from this page https://www.cfd-online.com/Wiki/Turb...ary_conditions
But I do not know the turbulence intensity of my flow because the value of root-mean-square of the turbulent velocity fluctuations (u') and k.
I also attach my 0 directory.
I really appreciate all the help from you guys. Thank you very much..
febrianbaehaqi is offline   Reply With Quote
Old   June 23, 2020, 08:35
geth03 is on a distinguished road
https://www.cfd-online.com/Tools/turbulence.php
use this tool to find your initial values for turbulence properties.
in my case, my simulation results are not sensitive to initial values of turbulence properties. but thats not a generalisation of course.
you need to test your case.
febrianbaehaqi likes this.
geth03 is offline   Reply With Quote
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
Internal Flow Instability with layers Zephiro88 OpenFOAM Running, Solving & CFD 1 June 20, 2019 04:20
decompose dependent solution arionfard OpenFOAM 3 December 10, 2018 09:36
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 14:05
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
