April 23, 2010, 11:29 |
internalField nonuniform <List>;
Andres
Rep Power: 16 |
Hi everybody!
How do I make the list for internalField nonuniform <List>;? this is for the 0/pd directory in interFoam |
July 14, 2011, 16:05 |
Tushar
Rep Power: 14 |
Even I want to implement nonuniform internal fiels for pressure... Can anyone tell me how the cell numbering is set in OpenFOAM?
August 26, 2011, 14:19 |
#3 | |
muhammad El-nashash'ee
Rep Power: 14 |
the numbering begin in x-direction then y-direction then z-direction eg. //loop for changing z for(int i=0;i<NocellsZ;i++) {//loop for changing y for(int j=0;j<NocellsY;j++) {//loop for changing x for(int k=0;k<NocellsX;k++) { //put the value here } } } |
August 28, 2011, 18:38 |
#4 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
@tsikroria0: if you WANT to program it in C++ have a look how utilities like engineSwirl and setFields do it. If you just want to set the field and go on: search for funkySetFields |
August 28, 2011, 19:12 |
Rep Power: 14 |
yes i have tried my code on one block, but i made a c++ program outside OpenFoam to read the output of blockMesh and assign the value of my internal field to the centers of cells by changing the files in "0" directory by using:
internalField nonuniform List<scalar> 'No.ofOverallCells' ( //data entered here ) ; if there is another way to doing so for multiple blocks please tell me that way. |
August 30, 2011, 05:52 |
#6 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
For the general case if you don't want to do use the OpenFOAM-API your best guess is to let an OF-program write out the cell centers of the mesh and your program reads that in and acts accordingly |
August 30, 2011, 06:06 |
Rep Power: 14 |
how is that???
August 30, 2011, 07:29 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
August 20, 2013, 13:06 |
#9 |
hekseli
Rep Power: 13 |
Hey!
I would like to have a nonuniform initial condition. I have a arbitrary boundary and I know the flow values in the boundary cells/faces. Apparently I could use interiorfield: nonuniform and give the values as a list (x,y,z,value). But because I want to start the simulation with these values and the mesh is not created by blockmesh, I have no idea about the order of the list-values in nonuniform condition. I tried to check but swak4foam and setFields seem to be for analytical expressions but I want to work with a truly existing list? Any ideas? |
August 20, 2013, 15:12 |
#10 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
May 25, 2016, 11:23 |
#11 |
Zhoujiang Deng
Rep Power: 10 |
Dear Bernhard,
Now I want to input nonuniform values(scalar a) in internal field which has a relation with y coordinate: scalar a = k*y + b; How can I do that? Zhoujiang |
October 26, 2016, 08:47 |
swak4foam
#12 | |
Rep Power: 10 |
Maybe it's too late for you but I've just found and tested this tool: swak4foam. You must follow the installation instructions for attending all the requirements. An example: expressions ( alpha1expr1 { field alpha1; //field to initialise expression "0.8"; condition "(pos().x<0.0)"; keepPatches 1; //keep the boundary conditions that were set before } alpha1expr2 { field alpha1; expression "0.8+100*pos().x"; condition "(pos().x>=0.0) && (pos().x<=0.001)"; keepPatches 1; } alpha1expr3 { field alpha1; expression "0.9"; condition "pos().x>0.001"; keepPatches 1; } ); |
September 2, 2019, 11:09 |
internal field nonuniform
#13 |
Kumar
Rep Power: 6 |
can anyone say what is the meaning of this internalField nonuniform? What is the meaning of the numbers 0....., 1....... and so on? What to do if i want to use uniform conditions?
FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object alpha.water; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField nonuniform List<scalar> 1875 ( 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ) ; boundaryField { inlet { type fixedValue; value uniform 0.5; } outlet { type inletOutlet; phi phi.water; inletValue uniform 0; value uniform 0; } walls { type zeroGradient; } defaultFaces { type empty; } } // ************************************************** *********************** // |
September 2, 2019, 11:12 |
multiphaseEulerFoam - bubble column in a T junction channel
#14 |
Kumar
Rep Power: 6 |
Hello all, I wanted to change geometry of the bubble column in multiphaseEulerFoam file into a T-junction channel. I changed the conditions in the blockMeshDict. But the contents of the alpha.water and alpha.water is difficult to understand. Can anyone say what is the meaning of this internalField nonuniform? What is the meaning of the numbers 0....., 1....... and so on? What to do if i want to use uniform conditions?
September 2, 2019, 11:51 |
#15 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
RTFM https://cfd.direct/openfoam/user-gui...17-1310004.2.8
Problem with nonuniform boundary conditions | qtian | OpenFOAM Pre-Processing | 4 | January 12, 2018 15:03 |
nonuniform velocity at the inlet | sambatra | OpenFOAM Running, Solving & CFD | 5 | June 17, 2014 17:39 |
nonuniform boundary condition( U=f(y) ) ? | panda60 | OpenFOAM | 2 | November 5, 2009 12:28 |
problem with internal field and nonuniform list | OFU | OpenFOAM Running, Solving & CFD | 1 | October 5, 2009 03:35 |
Set nonuniform boundary values | nikwin | OpenFOAM Running, Solving & CFD | 1 | November 30, 2008 07:12 |
