using transformPoints in a bash script
Like Tree2Likes
  • 2 Post By HPE
Old   September 22, 2019, 07:16
Default using transformPoints in a bash script
koful is on a distinguished road
Hi everyone.
I would like to ask a "probably" very easy question. I am a little bit newbie at linux bash scripting.
I have a center of mass point "p", which comes from another calculation. How can I use it in tansformPoints command? I tried these different ways below but it does not work...
p="(0 0 0)"
transformPoints -translate '($p)'
p=\'\(\ 0\ 0\ 0\ \)\'
transformPoints -translate $p
trans='transformPoints'\ '-translate'\ \'\(0\ 0\ 0\)\'
$trans
I do not know should I post it at linux forums or openfoam forums.
koful is offline   Reply With Quote
Old   September 22, 2019, 08:04
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Have you sourced OpenFOAM bashrc before executing the bash script or inside the bash script?
Don't know the error type you get, yet the bash script should be informed regarding the OpenFOAM command 'transformPoints'.
HPE is offline   Reply With Quote
Old   September 22, 2019, 09:10
Hi. Thank you for your response.
Yes I did. The other commands at my script are working. Like blockMesh or checkMesh. The error I got is:
"--> FOAM FATAL ERROR:
Wrong number of arguments, expected 0 found 2
FOAM exiting"
Old   September 22, 2019, 09:30
HPE
HPE's Avatar
Have a go, if possible:
#!/bin/sh
cd ${0%/*} || exit 1                        # Run from this directory
vector="(0 0 20)"
transformPoints -translate "$vector"
jipai and SimpleSIM like this.
Old   September 22, 2019, 10:22
#!/bin/sh
vector="(0 0 20)"
Thank you very much sir. It worked.
I tried lots of configurations but seems like I missed this one.
Thanks again, have a nice day.
bash, meshing, openfoam, scripting, transformpoints
Batch scripts Bdew8556 OpenFOAM Running, Solving & CFD 35 September 21, 2020 03:27
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
bash script information FluentStarter STAR-CCM+ 6 January 31, 2017 11:17
CCM+ bash script output format hebeldebel STAR-CCM+ 1 February 20, 2014 07:38
run openfoam with bash script Gosi OpenFOAM 2 April 11, 2013 09:10
