May 16, 2017, 10:08 |
Time-dependent water level height at inlet
Rep Power: 16 |
Hello all,
I am simulating a multiphase flow (water air) in an irregular domain that has one patch and other boundaries are closed (walls). I want to vary the water level height with time in a periodic manner at the patch. The change in water level will drive the flow in and out of the domain. Do you have any pointers on how it is best to do this? |
October 29, 2019, 08:16 |
Beibei Xu
Hi FUSIJ:
I have the same problem as you, do you solver your problem now? If solved, could you show me the suitable boundary condition? Thank you! Beibei |
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 41 | August 23, 2023 02:48 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
