Apply a velocity time-dependent at a moving wall |
January 4, 2020, 04:24 |
Nicola D'Ettole
Rep Power: 7 |
It is possible to apply a velocity time-dependent at a moving wall?
Regards |
January 7, 2020, 14:52 |
Pablo Higuera
Rep Power: 19 |
Hi Nicola,
this is certainly possible, I have programmed a BC in which you can specify the displacement of the boundary as a time series. Converting your velocity time series to displacement should be straightforward. I use it to drive piston and flaps to generate waves: https://www.youtube.com/watch?v=Pcg7CIowmhg You can find all the information and examples in: https://olaflow.github.io/source-code/ Since the source code is available, you can modify the BC to suit your needs. Best, Pablo |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 05:49 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
