KH Instability
Old   April 7, 2016, 03:32
Question KH Instability
Andela's Avatar
Marija Bervida
Andela is on a distinguished road
Hi all!
I am new to CFD and OpenFOAM, and this is my first post here on forum.
Lately I am trying to simulate Kelvin-Helmholtz instability in the atmosphere, which can be noticed in "wavy" clouds.
I will describe what I did for now, and I would appreciate your help (advices, comments).
My problem consist of two layers of air with different speeds and different densities.
Because this is case between two layers of air in which density difference is not so big like it is in a case of KH instability between air and water I don't know if I can neglect it, because the shearing will appear due to different velocities.
My domain looks like this: (box) 10 km (x dir) x 1 km (y dir) x 400 m (z dir).
In y direction i divided inlet on 2 equal part, and for boundary condition I put different (uniform) velocities on this inlets. On outlet I put pressure to be zero. And for all rest I put zeroGradient conditions (and empty iz z direction, because of 2D). Is that ok?
(I saw somewhere on forum when was word about KH instability between air and water someone suggested to put cyclic boundary condition in flow direction.)
I am not sure which solver to use.
For now I run several simulation using icoFoam (incompressible, transient) and twoLiquidMixingFoam (multiphase).
For start i used icoFoam to see how it all functions (setting up case, adding temperature like passive scalar to solver, ...). How KH instability would be like transitional case between laminar and turbulent flow, I am not sure about what to use (should I use turbulent model). For considering density difference (also for laminar flow) I used twoLiquidMixingFoam solver, where density difference is considered. I assumed some little difference in densities between this two layers of air 0.13 kg/m^3.
In icoFoam (laminar flow) density difference is ignored, and the waves occure due to difference in velocities.
Even I've got some nice results with multiphase solver twoLiquidMixingFoam (2 mixing incompressible fluids) and icoFoam I am not sure if these are appropriate solvers for this problem.
Also, I would like to add initial perturbation (some sin wave), but I don't know how. I searched way on forum but i still didn't managed to do it. It would be of use if I can get more detailed instructions.
I would really appreciate your advices and comments.
Thanks in advance,
Andela
Andela is offline   Reply With Quote
Old   April 8, 2016, 12:14
Thomas Evans
windscion is on a distinguished road
funkySetFields is probably a good place to start.
http://openfoamwiki.net/index.php/Co...funkySetFields
windscion is offline   Reply With Quote
Old   April 11, 2016, 02:32
Andela's Avatar
Marija Bervida
Thank you for reply.
I will try with it.
Old   April 12, 2016, 08:17
Andela's Avatar
Marija Bervida
Anyone other have maybe some suggestion or coment?
I would really appreciate anything. =)
Old   January 13, 2020, 16:28
Bodo1993 is on a distinguished road
I am wondering if you got any useful material on imposing perturbations.
Thanks.
Bodo1993 is offline   Reply With Quote
instability, kelvin helmholtz, perturbation
Kelvin-Helmholtz and Rayleight-Taylor Instability Tobi OpenFOAM 9 July 25, 2017 09:46
PISO algorithm instability in Python Nduna Main CFD Forum 1 March 15, 2016 08:26
Instability at the onset of natural convection Magherbi Main CFD Forum 0 October 23, 2002 09:53
Instability of convection Zeng Main CFD Forum 0 May 26, 2000 05:39
secondary instability?? Anan Main CFD Forum 2 April 6, 2000 09:48
